Saff rear beam mounts
Old Sep 18, 2012 | 07:20 AM
Default Saff rear beam mounts
What the best way to change these.Ive got a pair of poly ones to go in.Will i have to remove the beam from off the car.
I will change them when i put my other rear suspension arms on.
Old Sep 18, 2012 | 12:06 PM
martysmartie's Avatar
martysmartie
They are pretty easy to remove, one of inner ones of mine fell out when i remove the guide plate (yes I am going to poly mine as well) failing that you can put a large socket between the arm and the mount and GENTLY let the car down until the bush pops out.
Martin
Old Sep 18, 2012 | 12:36 PM
Rsmat's Avatar
Rsmat
I went and had mine pressed out for a Ł5
Old Sep 18, 2012 | 02:27 PM
cossiestu's Avatar
cossiestu
Martin
Do the poly ones pop back in easy?! If not, I guess a bit of lube will help!
Old Sep 18, 2012 | 05:07 PM
m4rkl's Avatar
m4rkl
If using the socket method put a block of wood on the chassis rail first
powerflex ones go back in pretty easy with a bit of lube
Old Sep 18, 2012 | 05:11 PM
Sounds like fun.Matt ive got a press at work if i get stuck.
Old Sep 18, 2012 | 05:34 PM
andy escos's Avatar
andy escos
doing the beam is alright to do but do not think about doing the trailing arms as they do not last 5 minutes before they are fooked.
Old Sep 18, 2012 | 08:16 PM
Im not gonna poly bush them now.Ive got another pair of trailing arms which im gonna use.Im gonna regrease the bushes and fit new seals.
Old Sep 19, 2012 | 02:50 PM
cossiestu's Avatar
cossiestu
And, if going for ally beam mounts, I'm guessing they don't need pressing in?!
Old Sep 19, 2012 | 04:51 PM
Yeh the metal ones come in 2 pieces and they just sit in the hole.
Old Sep 19, 2012 | 06:34 PM
cossiestu's Avatar
cossiestu
Like the sound of that!
Old Oct 5, 2012 | 09:12 PM
Anyone else have any info for getting these out.
Old Oct 5, 2012 | 09:47 PM
Phil2002's Avatar
Phil2002
as said above just use a 19mm socket, a jack and use the weight of the car to push the bush out
Old Oct 6, 2012 | 09:13 AM
So jack the car up remove the beam mount bolts and that plate.Place a socket between the chassis leg and the bush. Then put the bolt in bush and socket and tighten up. So the socket will push the bolt out when lowering the weight of the car onto it.
Old Oct 6, 2012 | 09:49 AM
fraser9764's Avatar
fraser9764
socket and a piece of wood, or you might find a patch of rust you never knew was there and loose your socket in the chassis leg
Old Oct 6, 2012 | 10:24 AM
JamesH's Avatar
JamesH
Old Oct 6, 2012 | 12:02 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the big ones that join the beam to the car this time around yes
i posted the method to do these in your last thread asking how to change the beam mounts (when it's your fault you didn't specify trailing arm bushes )
Old Oct 6, 2012 | 12:08 PM
The Youth.'s Avatar
The Youth.
the beam mounts are easy, get a big screwdriver in the side between them and the beam and prise them out, it helps if the centre tube section is removed first, but thats usually knackered and easy to get out anyway
I did my race car this way last year
steve
Old Oct 6, 2012 | 01:53 PM
Cossy Mike's Avatar
Cossy Mike
Originally Posted by JamesH
Last edited by Cossy Mike; Oct 6, 2012 at 01:55 PM. Reason: socket and a piece of wood, or you might find a patch of rust you never knew was there and loose your socket in the chassis l
Old Oct 6, 2012 | 02:35 PM
Fpmsl.My chassis legs are ok.I repaired the nsr one at the.begining of the year.
Ops sorry.
Old Oct 6, 2012 | 02:36 PM
steve
Thanks for that info Steve.
Old Oct 6, 2012 | 05:37 PM
dojj's Avatar
dojj
https://passionford.com/forum/6025070-post32.html
screwdrivers won't help shift them unless they are properly buggered, in which case you can remove them with a fish finger
Old Oct 6, 2012 | 10:36 PM
Thanks dojj.
Old Oct 7, 2012 | 08:52 PM
DAN-Saff's Avatar
DAN-Saff
I wouldn't be damaging my chassis leg with sockets etc you can make a puller - long threaded bar with nuts couple of arb washers and a spacer tube you can pull the bush out without damaging the car.
I can post a pic of the tool I use to do it if that would help.
Old Oct 8, 2012 | 12:58 PM
dojj's Avatar
dojj
You don't do any damage to the chassis legs mate, it's a very easy thing to donor the car is still all together as you only need to undo 3 bolts
Old Oct 11, 2012 | 06:20 PM
I will give it a try some time soon.Are the poly bushes easy to get back in.
Old Oct 11, 2012 | 07:35 PM
dojj's Avatar
dojj
even easier, simply grease them up and jack them into place
if they don't slot straight in just sit on the seat above the mount and they will pop in
when i did my first set it too about 30 minutes for both sides and i didn't know what to expect
Old Oct 11, 2012 | 07:37 PM
Cossy Mike's Avatar
Cossy Mike
I used a harmonic puller and a big washer. Grease them up and they popped straight in.
I was told they would need pressed in......disagree with this
I wouldn't like to try them when the beams on the car
The hardest bit for me was putting the bolt through the sleeve into the floor, it was right f on to get the bolts started
Old Oct 11, 2012 | 07:49 PM
paul16v's Avatar
paul16v
Monte 087
Watch your fingers when fitting them lol
Old Oct 12, 2012 | 04:36 AM
How did you get the bolt to start then.
I could talk the car to work and do them on a 2 post lift or take the car to my dads and do it on his garage floor using a jack and axle stands.
Come on then spill the beans lol.
Old Oct 12, 2012 | 07:32 AM
Cossy Mike's Avatar
Cossy Mike
The original mounts have a load of movement in them so you can just push them by hand and make them line up before screwing the bolt down.
The powerflex ones dont have any give by hand, I had to leave the opposite side screwed in by 7-8 turns then had to loosen off the 4 bolts on the diff mount to drop the beam more and give a bit more room.
Then when it's all lined up torque them up ( off memory they're tight 70-90nm)
Old Oct 12, 2012 | 07:36 AM
Cossy Mike's Avatar
Cossy Mike
just before they are ready to press in keep your fingers well clear, once they 'pop' in you'll understand!
Old Oct 12, 2012 | 09:01 AM
DAN-Saff's Avatar
DAN-Saff
I've done bushes on loads of saffs and if you jack it up like that trying to get the bush out it does.
Push the insert collars so they are about an inch above the bush locate in chassis rail put bolt in and then get a metal punch, centre it on the bolt head then jack the punch upto push the bolt to the threads then turn it in
Old Oct 12, 2012 | 09:09 AM
Cossy Mike's Avatar
Cossy Mike
You have PM
Old Oct 12, 2012 | 02:37 PM
Rsmat's Avatar
Rsmat
Fuckinhell 36 replies and still not done them...
Old Oct 12, 2012 | 04:30 PM
cossiestu's Avatar
cossiestu
Sounds like ally mounts might be a lot less aggro!?
Old Oct 12, 2012 | 04:33 PM
paul16v's Avatar
paul16v
Monte 087
Yes thats the one mate, fingers would deffo come a cropper
Old Oct 13, 2012 | 06:47 PM
I fitted them this afternoon.It took me about 2 hours to do them.I was suprised at how easy the bushes come out.The first poly bush i fittes went well.The nsr bush was a bit of a pain.I had the car jacked up,a jack under the beam and my dad was using a bit of a gurder to leaver under the wheels to push the beam forward so i could get the bush and bolt to line back up.
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
