12mm plenum spacer are they any good???
As above are they worth buying??? Also I got a 2wd an 4wd plenum on my 3dr engine which one is better???
as far as i know the 4x4 plenum will do 400hp any way & also i think its a 14mm spacer you need & not the 12mm the best way to check is measure the fuel rail mounting lugs on the plenum & see how thick they are ,that is how thick the spacer should be so the fuel rail will bolt straight on .
GGR sells new 4x4 rails as i have one on mine that i had modded - silver soldered AN6 fitting on
As Andy says you need the larger one
MSD sell them cheap http://shop.motorsport-developments....14mm-900-p.asp
4wd inlet manifold has better flow and volume than 2wd item.
MSD's 14mm spacer is a good with the combination of 4wd manifold. This spacer doesn't have fuel rail mounts because you can use manifod's on the opposite side(injector's side).
If you have a 12mm spacer then this spacer must have fuel rail mounts if not avoid to install it.
GTR_STU
28-08-2015 01:02 PM
