How much?!?! T5 Speedo Drive
Is this how much they are worth now?
http://www.ebay.co.uk/itm/1809767423...orig_cvip=true
I've got a spare one that I keep just incase but if it worth £122 I think I might sell it.
Rich
Rich
I've just bought these off him on eBay:
http://www.ebay.co.uk/itm/1809767115...84.m1497.l2649
Bargain of the year
Rich
Is that Mark off here?
Bargain of the year
Rich
Bargain of the year
Rich
did you get my pm regarding the oil feed
This is the problem with these turbo's - it's exactly the problem i had with mine plus my actuator is located on the inside so i needed to go over the top hence the extra length.
Well let me know if you get some sizes etc and i'll see what i can do - mine was made from scratch using the old setup i had made of AN extensions etc but was leaking which is why i went for a one piece unit
Cheers Rich
AN4 with a 5.0mm bore to M11 restrictor with 1.0mm bore
I had the hex part higher up so i could tighten at the top of the fitting instead so i could get a deep socket on and not struggling around the base where their's no room where the housing bolts are.
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
