ABS romoval/disconnecting/bypassing loom???
Hi all, I'm after some info on the ABS on a rwd Cossie, i'm in the middle of trying to sort the wiring loom out on my RWD S2 ERST project and after digging the loom out i found black plastic covers on the rear ABS sensor to be badly cracked (as they do).
I've seen/read on another thread in the past that someone has used a replacement loom so as to do away with the ABS system and the new loom powers up & operates the ABS pump etc.
Can some one point me in the right direction to who makes these loom.
Thanks
Ginger
Thanks
Ginger
Thanks
Ginger
Thanks
Ginger
I had to get the modification certified, which in NZ was not a problem, other than the cost.
muz
30-09-2015 08:29 AM
