Cosworth rattles, bumpy
Hi, my cars a bit bumpy and rattley for me, so i removed the coilovers and fitted koni's. i was thinking of changing all the bush's with the Powerflex ones.
Will it make a difference? Or what would you guy recomend?
Depends what springs you have, and on how you have set the Koni's up?
Yes worn bushes can make things "rattly" as they would have play in them, tbh poly bushing should be on the cards anyway, as the bushes are almost certainly past there vest.
Just don't change the trailing arms "spherical" bushes!
Obviously due to the nature of the car, it's always going to have a fairly 'firm' ride!
Martin
Martin
the rear arms have a spherical bearing not a bush. this reduces the movement in the joint giving better handling. a few people on here have destroyed bushes in a few miles.
the spherical bearing is also known as a rose joint. a rubber bush allows some movement to cushion and insulate the suspension, its also cheap!. the spherical bearing allows virtually no movement improving the handling immensley.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
