Replacing saff cossie rear trailing arms
Received 1,044 Likes
Just wanna know can i remove the hub with the bearing carrier or do i have to remove the big hub nut and do it that way.I was thinking about removing the allen key bolts from the drive shaft then remove the hub and bearing carrier in one,thats if the hub will come out of the hole in the trailing arms.
Hopefully i will be changing the rear arms this weekend.
If you are trying to take the hub carrier off the rear arms and then bolt them back onto some new arms without undoing the big hub nut you can, you need to undo the drive shaft bolts and remove the calliper and disc, then you will see a hole in the wheel flange which allows you to fit a socket through to get to the four bolts that hold the hub to the lower arm, just rotate it to get to each bolt.
Doing it like you describe only works on Sierras with rear drum brakes, but not with disc brakes. The back of the stub shaft is just as thick as the actual CV joint, because the bolts are right at the outside of the CV joint. On drumbrake Sierras the CV joints thinner, but even some drumbrake CV joints are too thick to go through the hole in the arm.
Brammer i will have a look at it tomorrow.I have to go to my dads to get the big 41mm socket out of my tool box.My backing plates are nackered so im just gonna take them off.
I replaced my arns today.I dont know if you can do them with the beam in but i dropped the lot out cause i wanted to put some more underseal on the chassis legs since i will be using it through winter.
The osr brake flexy pipe from the caliper to the trailing arm nacked up so i had to buy one of those.
Also noticed the fuel tank was leaking so ive took that out and its gonna get repaired this week.It must of been out before cause the captive nut wasnst there.It was a nut and bolt.
Bloody old cars lol.
I'm a Cu*****nt my apologies what was I thinking, and I wasn't even drunk when I wrote it
What makes it worse is I only just put mine back together at the start of the summer
No bother matey.I took the wheel bearings out too and regreased them too.
I was a bit pissed off about the petrol tank cause i was wanting to drive my car again.Looks like its gonna be next weekend now.Ive still got a nsf suspension arm and poly bushes to fit.
It's always the same mate you start one job then find something else that needs doing and before you know it, the car that was meant to be back on the road for summer sits doing nothing for yet another year.
Yeh thank fook.I changed the front suspension arms poly bushes too.Whats the best way to get the holes to line back up for the bolt to go back in the sub frame.
I was fooking about with the drivers side for ages.I put the wheel back on then lowered the car down and it lined back up lol. I hate doing these arms.
jessie_rs
11
03-06-2019 04:57 PM
155lee
14-09-2015 07:37 PM
Anutternutter
21-08-2015 06:07 PM
track.focus'd
12-08-2015 05:53 PM
