- Sapphire 5 year restoration , MOT day
- Power Steering pump Sapphire 4WD
- 4x4 sapphire ecu
- Relay Indentification 3 Door
- whats the best ? airbox or cone filter or cone filter in a box ?
- 4x4 cossie/2wd brake questions
- Piston Rings
- 3door project
- Roll cage in a saff
- petrol tank
- Zetec?
- what happened to the thread "Rare sapphire 4x4?"
- Saph 4x4 ecu issue
- Which tyres for my newly refurbed standard 3dr alloys??
- general buying advice
- T34 vs T35 (TB3403)
- Clutch peddle
- old school
- A pillar weatherstrips
- Need help with oil jet!!!
- Fitted my Cobra Imolas into the 3 Door
- saff cossie alternator
- Turbo kits for the 2.9 V6?
- Would anybody buy a cat c 4x4 sapph cosworth
- T3 & T35 turbo question
- Cosworth yb cylinder head.
- Sapphire cosworth
- 044 fuel pump
- Any pics of saphs with comp mo Flat 5's
- Cortina 1.6 to mk1 Sierra engine swap ? Advice
- 2nd gear input shaft cosworth
- sierra roll cage question
- Cossie Lhd throttle/clutch cables
- Info required on mountune mt21 &mt23 camshafts
- wireing woes of a 3 door
- VRT exhaust emissions
- Front brake uprades on a budget, whats available
- YBB powered Merkur
- Re build average prices?
- Uprated camshafts in 2wd cosworth
- 205 block fuel pump drive blank
- water pump help thanks
- Strut tops? Gaz Golds...
- Changing loom in 3 door
- 4wd std cams wanted
- HELP needed with cossie
- step 1 of 3dr project-making my shell rolling
- MOT
- Sapphire steering bush.
- 3 door and spec R strut brace
- Vibratechincs 2wd gearbox mount
- 3dr manifold?
- Diff Oil
- my sapphire in performance ford
- Running issues 4x4 sapphire
- Thread size for 2wd oil pressure switch?
- Sierra 2.0 Dohc Carb into a 1.8cvh idea's ?
- YB Piston ring question
- D623 SRB
- window switches
- Spec'ing up my 400bhp Cossie Lump. Have i missed anything?
- 2wd Saff owner new to PF
- D40 TYRE
- Smoked Backlights!!!!
- My old Sierra is on eBay.
- block paint
- 2wd sump gasket ?
- cosworth fan direction
- My magazine article printed
- So I bought this 205 bottom end..... Advice please
- Sierra 3 door dashboard
- N7A in sierra saphire,i need help”””
- Reshelling my shapphire
- Boost issue please help
- New doors
- T34 Turbo oil feed
- possible wheel swap
- Loads of revs
- Paint code
- Cosworth Power Steering help needed
- Saphire problems
- Rear beam poly bushes ? Steerig rack Q
- Need to get some slim rad fans
- sierra cosworth on car sos nat geographical channel
- Changing Propshaft Bearing
- Any one know of a 3 door cos breaking
- which engine oil for yb cosworth?!
- Power steering pipe banjo fitting
- Pinto and 2wd YB engine mounts
- RPMs jumping only when idle
- sierra cosworth camber shims
- help help help?????
- Unique (I think) brake upgrade for my saph
- How much benifit is there with wasted spark?
- Ford Part Numbers for:
- omex rev limiter? xr4x4 2.8?
- learn new things everyday
- Helps souring a few 3dr bits - where from?
- 3dr head lining
- Cosworth 4x4 steering rack ??
- Waterless coolant
- Recommend valve stem seals please for my YB
- saff eletrical issues
- mk1 sierra!!
- sierra 2.0 efi dohc clutch
- Estimate my power please
- T34.63 with Siemens 83lbs
- Help with Sierra 2.0 EFI Dohc
- Diff ID
- fuel system question
- Valuation for Insurance
- L6 TPS wiring
- Sapphire heat shield
- 3 door headlights
- Cosworth graveyard
- wasted spark issue
- few newbie question
- l8 ecu
- sierra saphire bulkhead panel
- Fitting front strut brace ??
- Sapphire rear seats?
- Where can i get one?
- need help cosworth yb headgasket
- Siemens black 83lb injectors
- chip board
- 2WD cossy fule pressure regulator
- Anyone remember this Saff or know of its whereabouts?
- piston size help
- Stand alone management???
- How many 'M' plate Saph Cossies were made?
- Anti lag a 3 door
- how to adjust clutch cable
- HTdistribution ht lead diagram
- Lost a few bolt sizes (YB)
- First ford and first cosworth
- Couple of Pic's
- Any pics of Moonstone 3dr with black RL5/RL7s?
- Clutch pedal problem
- Sierra Zetec
- Front prop uj??? Help
- black sapphire 4x4 paint code?
- how toconvert 2wd to 4wd???
- Changing rev counter
- Sapphire spoiler gaskets??
- Boost very late in first gear
- Τ5 gearbox Bearing - Tailhousing bush
- Converting 4x4 saph to 2wd? Info please!!
- finally got mint sunroof and snapped bolt in handle
- Horn wiring
- dbilas dynamic crankshaft for sierra
- T34 & T35 Difference's??
- Mt75 hybrid for BOA BOB CONVERSION cheap!!
- Idle problem_cold start
- Injectors
- Keeping a cossie outside
- Gripper into cossie diff
- fianlly got the pics up of my white 2wd cosworth!!
- 3dr fuel/brake lines
- 2wd heat shield - painting it???
- D527DPG???
- Sierra horn problem
- Do Mondeo steering wheel's fit Sierra's?
- Saph Boa turbo conversion!!
- Running charge cooler and intercooler?
- T5 gearbox discussion
- best place to buy front wheel bearings for 3dr hubs
- best way to remove poly beam bushes
- MSD Chip
- Saph rear light gaskets?
- safe boost
- saff cosworth 4x4 front shocks vs escort cosworth 4x4 front shocks
- 2wd loom or 4x4 loom?
- Boost comes in
- mk2 front wings original ford or aftermarket?
- headlights not workin
- 2wd plug gaps
- Dont think my Spec r dump valve is suited to my sapp
- Rear Diff
- Yb Running problem when hot
- Sapphire front window rubbers
- Rear window defroster
- 3 dr bumper help please
- power steering braket bolts
- Saph cos rear spoiler size please
- Making your own brake brackets
- Chassis wiring clips
- T4 turbo
- Compression strut, anti-roll bar then?
- £20k saph.
- 2wd starter
- 3 door cosworth seats problem
- Window wiper arms???
- Thickness of standard head gasket and some other values
- A few pics of my cossie
- Saw this on Ebay
- Prop shaft choice HELP!
- interior cleand and re upholstered
- Comp ratio suggestions please
- what is the max bhp throw standard 4x4 running gear?
- setting adjustable tca on a cossie.
- Arch Liners?
- sharktooth wheel nut cover caps
- Leather door card
- help needed in sourcing a seal
- l8 ecu but which crank pulley? 36-1 or 4 lug?
- sunroof question
- Rear coilovers on cossies
- ideal weight for a flywheel on 4x4 cosworth?
- fuel tank breather valve sierra cosworth
- Rear beam bushes alloy or poly ??
- Rs500 splitter recommendations
- Main service of Cosworth. Parts and places.
- Lambda sensor to L8 MSD closed loop.
- New v Old
- oil pressure/temp sensors in 4x4 oil filter arm?
- 4x4 sierra cosworth front wilwood bells
- question of cost
- which one -31 or -34 ?
- Sierra 18" alloy pictures
- Are these correct head lamps for a 3 dr ?
- Grey injectors
- 2wd heat shield fixture question
- Bearing Covers
- Passenger side genuine ford mk1 wing
- help needed sierra 4x4 cosworth
- Cable
- turbo hanger cosworth
- Would you buy a patched car?
- will et20 17x8 rl7s fit the back of a saff
- Twin or Grp.A oil feed? (wet sump)
- Engine rebuild , on going
- engine bay repair?
- Speedo cable jumps out of speedometer
- 88' Sierra non-PAS => PAS
- cosworth cam help ?
- Cossie Engine Breathing
- Refurbished Cam Cover
- camber on a sierra cosworth question
- Hart inlet ? 4x4 inlet , rs500 inlet ?
- 3dr.. Omp rear strut brace .. Fitting..?
- strut braces
- closed loop turbo ecu wasted spark help please
- Part query
- Jenvey / Penny and Giles TPS
- spent some time sorting the cossie this week end
- which 2wd diff oil ?
- BOA fitting, whats needed
- Washer location in cosworth rear beam?
- 4wd coilovers onto 2wd?
