turbo hanger cosworth
heffo
i lost bolt out of turbo hanger the bolt goes down through ganger into head .i dont know if theres also a sleeve around bolt or if bolt is heavier on the shaft and smaller at threaded section as threaded part is 8mm but hole in hanger is about 18 mm .anyone able to tell me .thanks in advance.
I think from memory it's just the bolt and a thick washer the reason the hole is larger than the bolt is to allow you to move the hanger around to get the right adjustment/spacing.
That rubber bush in that eBay advert is a bit strange I can't see how that would work?
I just had a look in the workshop manual and it just shows as I mentioned above just the bolt and thick washer bolts through the hanger block onto the head.
yh i was told it only has a washer by a few people som1 must have made that bush thing
Matt Baxter
16-09-2015 08:30 PM
