PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72
  1. 4x4 Sapphire G859 WBJ
  2. Bigger discs with original 4*4 rear calipers?
  3. How much boost?
  4. Help
  5. How do I install a GrpA coil?
  6. Cosworth engine bay cleaning tips please.
  7. Sapphire 4 x 4 Bulkhead panel replacement
  8. Broken 3rd gear 4wd Saff- replacement suggestions
  9. studs and nuts or bolts
  10. Full Bare Metal Respray, How Much?
  11. Cossie's in Cornwall!
  12. half roll cage??
  13. Supercharger
  14. Shock Absorbers
  15. How much power can a T34 make?
  16. my new wheels wot do ya think
  17. Show us your 3dr cossies
  18. interior color
  19. fitting defi oil pressure gauge
  20. How many ????
  21. inter cooler
  22. help please!
  23. what board to run anti lag etc
  24. 3 door windscreens?
  25. 4 pot caliper bolts
  26. Show us your saph cossies
  27. wooohooo ive just got myself a saphy!!!
  28. head job
  29. is it a L6 or L8
  30. idle valve problem
  31. 2wd Brake question
  32. 2wd cossie not starting ?
  33. Power?
  34. What size tyres for 4x4 Saph?
  35. is it escort or sierra????????????
  36. 3dr price
  37. Trying to fit AP cp6600 calipers to a sapphire
  38. rs500 at the haynes museum
  39. safe power for 4x4 block and crank
  40. grpA coil
  41. xr4x4 site
  42. dump valves?
  43. 3dr 205 Block - how much power???
  44. TURBO COOLER.
  45. Flywheels
  46. sierra 2.i efi pinto
  47. turbo cover
  48. Where to find a SECS monitior
  49. Moonstone 3dr,HOW MANY?
  50. sorted @jam sport
  51. Wastegate Chatter
  52. 3dr Sierra RS Cosworth Service
  53. sierra 2.0 8v gls
  54. 3dr Cossie chassis numbers
  55. Which one??
  56. escort cos rims on 3 dr
  57. urgent help required!!!!!!!!
  58. doner car
  59. How can we install it???
  60. 4x4 cosworth x member on 2wd ?
  61. fr34 cam
  62. Cosworth cylinder head torque wrench settings ?
  63. 2wd/4wd intercooler
  64. sapphire cosworth help needed
  65. Cornish Cos for Evo trade in
  66. screamer pipe
  67. Identifying exhaust/inlet cams Cosworth 3dr
  68. !/4 mile standing starts
  69. Front electric window mechanisms
  70. Which Turbo for Stage 3 Sapphire 4x4
  71. Cosworth Racing Pistons
  72. Mate is going to look at RS500- what chassis & eng numbe
  73. Cossy 4x4 engine and running gear inot a Xr4i shell
  74. Uprated Propshafts
  75. ST 170 Rims on saphire ????????
  76. Ford Sierra GT
  77. cylinder head
  78. What about the wheels like
  79. standard ride hight for a 2wd sapphire cosworth?
  80. long studdeded bolts help please
  81. Cosworth Cranks
  82. RS500 Optional BBS ?
  83. don't you hate it when
  84. Cosworth Recaros
  85. whats it worth.
  86. 4x4 cossie electrical problem!! please help!!
  87. how good are they?
  88. Cannot find topic with difference between red and green top?
  89. standard low mile saph or 350bhp low mile saph?
  90. Does any one know how many moondust sapphire cossies
  91. Wheel choice
  92. Engine flush, bad or good??
  93. MT75 quickshifter
  94. kangaroo cossie
  95. How do I?
  96. Who uses air/fuel ratio monitors & what ones
  97. cam belt
  98. Ok then whots the cost of fitting a new clutch
  99. Looms
  100. how many in each colour rs500`s left
  101. Is it bad ignition coil ref ???
  102. how much would you pay???
  103. Sapphire Cosworth Costs
  104. parts for ecu change?
  105. What colours did the RS500 come in?
  106. Rev Counter 1000RPM out
  107. help please cossie peeps
  108. 3 DOOR pedal box?
  109. abs problem
  110. my rs500
  111. saff cossy colour
  112. Whats the best diff?
  113. Radio reception in Sapphires?
  114. Fuel line connector
  115. Saph Heater problem
  116. Opinions/experiences/pros and cons on Poly bushes
  117. Gearbox/Speedo puzzle!
  118. -31 actuator
  119. will it fit
  120. Ahmed Bayjo chip
  121. Some old pics of my car
  122. vibration on pull off
  123. Lugs on cossie heads
  124. saff cosworth replica??????
  125. were are thay hiding? type 9 box
  126. Little Help
  127. fitted some new bits today
  128. Bosch dynamo/generator, Cosworth
  129. Water Leak on Saph??
  130. Fan wont stop and i cant find the fuse help please
  131. Blown Head Gasket
  132. Sandblasting inlet manifold? any good or harm?
  133. washer jets
  134. Boot lock 3 door
  135. tips please(500cooler)
  136. t-56 box
  137. What difference between Air Box RS and RS 500 ?
  138. saff morettes?
  139. help identify ECU
  140. Transmission loss
  141. psi for stage 1 mountune chip????
  142. Question,engine building???
  143. 2wd fuel rail
  144. rs500 original exhaust downpipe-whats it worth?
  145. Laguna front splitter?
  146. T34 Turbo Exhaust Housing
  147. 4wd cilinderhead, turbodamper/exhaust manifold?
  148. 3door fuel guage
  149. Torque settings
  150. Has anyone got pics of Goodridge brake lines on the car?
  151. p100 truck to be modded. help needed. what am i looking 4???
  152. fuel tank !!
  153. saph 4x4 silly little probs
  154. 2wd engine build
  155. Substitute parts
  156. Looking for 3dr cossies Tachometer
  157. Advice on fitting a RS 500 Style Intercooler
  158. injectors
  159. 4x4 cosworth engine moving
  160. any one know the finis code for a saph cos fan sender????
  161. wot r
  162. The best way to tighten the rear end under braking?
  163. Thermostat Housing leaking
  164. Stupid quick question -can a 2wd saph exhaust fit a 3dr?
  165. 3 door with sagging shelf: What to do?
  166. Just done this
  167. stg 1 ap clutch
  168. ABS pump leak 3door
  169. Boost adjustment
  170. crap cossie brakes
  171. What years were Sierra/Escort Cosworths used in competition?
  172. What's the difference between light & dark green injecto
  173. Oil Breather on Cos
  174. in car computor
  175. How Dangerous
  176. Black Saphs?
  177. what mods can you see?
  178. range
  179. Where to buy T34 or T35 turbo?
  180. turbo oil return hose
  181. Optimum wheel and tyre size for PERFORMANCE not bling doh!
  182. Magenta Cossies
  183. Whats the biggest rims you can get on a sapphire?
  184. Newbie with some questions. Mainly MT75 4x4 box...
  185. which spark plugs
  186. Stage 1, Stage 2, Stage 3 - what are the definitions?
  187. strange ABS
  188. any ideas how much a 45obhp rebuild will cost me???
  189. Sierra 2.0i Ghia - Help with tyre choice!
  190. balieys brether fittin prob
  191. wrc headgasket
  192. L Redg Sapp Cossie 4X4
  193. Who has the best price on rs500 style intercooler?
  194. COSSIE Colour?
  195. cluncking sound when putting into gear
  196. 2wd gearbox oil
  197. Engine miss only when engine is warm !
  198. Want to sell parts
  199. Carbon fibre turbo heatshield
  200. ford motorsport L8 chip+pectel
  201. Cosworth (2 wheel drive) Rear Diff Mods
  202. Urgent Help Needed.
  203. 2wd Sapphire Diffs
  204. 4X4 PROMO PACK
  205. Found out the hard way the cambelt needed changing...
  206. Rear shims
  207. L redg sapp cossie 4x4
  208. fittin sunroof
  209. Ignition switch ???
  210. Lets see your RS500 pictures!
  211. is my cosworth fooked?
  212. skimmin a 2wd head?sorted
  213. Sapphire front spring 4x4 instead 4x2
  214. Cosworth valuation?
  215. stage 1
  216. Wastegate chatter or dump valve whoosh?
  217. anyone like to value my car from these pics and details
  218. Which fuel pump for stg. 3 Cos?
  219. YB0611 Gasket set.... where from???????
  220. faulty lights
  221. Rouse Sport Bits
  222. RS 500 side stripes lengths?
  223. Spark Plugs for Stage 3 4 x 4.
  224. Check Link
  225. 2wd actuator needed money waiting !
  226. gp n mountunecossie engine& grey injectors from rally ca
  227. 2 stage boost / wiring and questions from NZ
  228. sierra 2.9i 4x4 cosworth ghia 1989
  229. rs500 help wanted
  230. Loads of White Smoke!!!
  231. Dsitributor
  232. Starter Motor for 4wd Saff
  233. where can i found grA anti-roll bar elements
  234. Exhaust question
  235. So I took the dipstick out and there was NO oil on it...
  236. fuel cells
  237. What next???
  238. New Sierra 4x4 shell XR4x4 or GLS??
  239. diff problem
  240. Dash ECU cover
  241. 2wd cossie front anti roll bar
  242. 330 2WD Saph Plugs
  243. whats a set 3 dr alloys go for now?
  244. Wheels over cossie brakes
  245. clutch cable on 2WD saph anyone?
  246. Stage 3 4x4 cossie
  247. Wheels???
  248. whats the best exhaust
  249. crankchaft measurements
  250. cossie on lpg
