Wastegate chatter or dump valve whoosh?
That's what I got asked today, while discussing proposed Stage 3 upgrade for my 4b Sapphire...
He did go on about lag etc. but my eyes started to glaze over...
The proposal is: exhaust, 3-bar map sensor, -31 actuator, Ahmed chip, cone filter, looking for 330 bhp.
Seems to be a hot topic of late - see https://passionford.com/forum/viewtopic.php?t=74261 for more info and advice.
Testing the future
i run without a d/v. i find the engine more responsive, with no more lag on gear changes. i run without to eliminate problems that can arise when the d/v leaks.
No probs - am running a dump valve and cone filter on my Stg.3 4x4 Saff - get the whoosh at low boost but good strong chop of air back through turbo when foot down. Not really thought of trying it without DV - may give it a go but seems to run just fine as it is. Worth knowing from various posts and opinions on her that it appears no more detrimental to the turbo to run the car without....
there is no sound like stag 3 chatter,it reminds me of the old rally cars,my 4b has a cone filter from quick shift racing and a polished pipe the sound is awesome
Location: Out Shooting Burgelers, cause thats what Norfolk people do!!!
I've found a better response without a d/v on spin up, and the chatter does sound better, but at the cost of your turbo's length of life.
Originally Posted by mattbibs
you have to run some serious amounts of boost for the turbo's life to be shortened by chatter!
i prefer the loud crack of a dumpvalve, specially wen drivin in built up areas as u dont have to go fast and everyone looks.
anuva reason is i get ppl thinkin my car is fake cos of not havin a vented bonnett (pre-90 2wd) so its easier for me to convince them otherwise wiv a dump valve
it not so much about the bhp figure its more what boost pressure you will be using. think i read the other day that a sustained 24 psi tends to blow up these T3's!
I didn't have a dump valve when i bought my 2wd stage 3 saph and loved the chatter, but put dump valve on to protect turbo. noticed it picked up better on gear changes... fresh cool air must make a small difference. have now been told you don't really need dumpy unless you're running monster T4!
Are dumpvalves somehow now available for diesels, had the 500 out last weekend and im sure the tit that pulled up next to me in his diesel rover had something like that on it, i had to laugh specially when he stalled it after reving it as much as he could so i could here the noise. very sad.
Don't differnt types of DV's make different sounds then?
I tohught group A ones chattered and ones like Baileys and Forge create the whoosh noise.......?
chatter every time it sounds fucking awesome dump valves sound gay and should only be used on fiats and renos. i had one when i got my car and it made both in relation to earlier posts but out the dv went first poss opp
mine has chatter and no dump valve
chatter has always sounded more like a rally car to me and sounds great on cossies
dump valves are for people who want to be noteced around town
DEYTUKURJERBS
Originally Posted by salmon
Whats that squeking noise you hear on rally cars out of interest?? (Malcolm Wilson old Michelin Pilot escort used to do it really loud).
Originally Posted by tont2002
wastegate noise (i think)
Originally Posted by puntoturbo
wastegate noise on rally cars is because of their external gate
i rather have DV and hi boost and sound like gay, than have chatter and let everyone know you dont have power in your engine.
i think that all show, no go shit should be avoided at all costs.
all Cosworths should be build by race spec, not race looks.
but race cars don't run hi boost they rely on quality of engine build so if you run hi boost your car bears no resemblance to race car as a wrc car is limited to little over 300 horse
WRC cars start from high boost at low RPMs and then begin to tail off into lower pressure as the revs build up. so actualy they run at hi boost. and there are many race cars that dont have restrictors, in other classes. rallycross for example.
and i know you just didn`t compare your cossie to the WRC spec car. WRC cars are custom build all around.
it seems it isn't just dump valves that sound gay and i quote " i know you just didn't " i wasn't comparing my car to anything as it happens, it's obviously a case of agreeing to disagree i suppose, in my opinion my point is valid in yours not so it seems
Dumpvalves are really useful when ur running high boost on a high BHP engine. Some people say the wastegate chatter on a High performace engine can damage the turbo.
