PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72
  1. mt75 quickshift
  2. front downpipe/help 2wd cossie
  3. cossie floorwells?
  4. Req: Bosch partno. (803 + fuel pump)
  5. sunroofs are saphs the same as 3 doors
  6. help need cosworth head asap
  7. Saff zorst
  8. Garrett T3 - .60AR Compressor - which cossies used them?
  9. saph rusty floor.
  10. VERY noisy fuel pump!
  11. RS500 at the Golden wheels show!
  12. Just got standard Saff 4x4 - Cheap ways to more bhp ???
  13. strip off strips?
  14. Rear axel?
  15. RS 500 with new wheels again!!
  16. How does a 3dr cossy sound?
  17. pics of mooonstone
  18. Cosworth valuation guys?
  19. My RS500
  20. How much do cossies actualy cost?
  21. rouse sport question
  22. surplus stuff
  23. Eccentric strut top mounts
  24. Power steering rack, 2wd - 4wd?
  25. 4x4 saph fuel filler cap
  26. Fitting a Fuel Computer to a Sapphire 1.8 GLX (1992 CVH)
  27. has any1 ever
  28. cossie loom help
  29. anyone ever put an mt75 2wd gear box in a cossie
  30. Cosworth Tuning in Scotland
  31. Realy Ford Motor Sport Chip
  32. FOR SALE : Intercooler, snowflakes x5, fibreglass skirts etc
  33. changing the head gasket
  34. 4x4 Cosworth running gear in a 3dr shell?
  35. Rs Cosworth 3 door insurance
  36. Wanted T34 must be new/mint condition. also privat plate !
  37. Will not hold boost !
  38. poly bushes
  39. Diff Ratio??
  40. gearbox problem
  41. RS500 Throttle Body
  42. the best turbo
  43. fuel pump rewiring
  44. RS 500 STYLE INTERCOOLER
  45. quick question
  46. l6 ecu testing
  47. Does anyone have info on this 4x4 brochure?
  48. Anyone got a standard 3-door and want to help with a feature
  49. My Cousin's just Brought a Saph Sierra.. Saloon
  50. Dave Wilson
  51. LOST FEED TO LARGE LIVE ON BRAKES
  52. NO STARTING BUT A STRONG SMELL OF FUEL
  53. very good find
  54. Engine rebuilt/Stage 1/Tuning advice please
  55. Cossie 4x4 stage 3 mapping sensing
  56. drinking lots of oil
  57. Staff cossie miss fire, dead spot
  58. 4x4 & LSD Question
  59. 6 Speed Gearbox
  60. HELP!! Whats the Difference??
  61. HOW MUCH???
  62. RS 500 virgin
  63. WHERE CAN I GET CARBON FIBRE BONNETS
  64. Boost Problems
  65. engine rebuild
  66. Cossie bits
  67. Boot locking problems
  68. 3Dr Side mouldings?
  69. oil pressuer plz
  70. 3 DR door locking motor prob?
  71. My new retrimmed seats!
  72. cossie standard suspension
  73. Sierra Cossie Vs Fiat Coupe 20VT last Sunday on M1
  74. whats the chances
  75. 4x4 Cossie
  76. 3 Dr Carbon Door cards, prices!
  77. Is this a 500 intercooler?
  78. oil and filter
  79. Why is my car over boosting?
  80. Ahmed Bayjoo
  81. oil and water temp gauge temps?
  82. 4x4 Cossie - how much can you expect to get if you break it?
  83. Petrol questions
  84. Baileys dump valve
  85. rs 500 intercooler
  86. cosworth heads
  87. Carbon Door Cards for 3 dr cosworth?
  88. moonstone 3 door on BBS split rims anyone?
  89. Rally car restrictors
  90. Anti roll bars
  91. Shim kits Sapphire, where to get?
  92. cossy 2wd intercooler - what's its limit
  93. Meshed Quadlights.......... Yes or No ?
  94. 3 door / RS 500 Wheel Locks
  95. 3dr Sierra Cosworth parts needed
  96. quick rack?
  97. 3 Dr Carbon door cards?
  98. Power Steering Fluid?
  99. smoke!!!!!
  100. 18's on a 3door
  101. poly bushes
  102. CO METER
  103. Nitrous Oxide on a Cossie engine
  104. Dunlop D40's
  105. poor cold start
  106. Brakes & Suspension
  107. Breakers Yards
  108. Cosworth Badges!?!?
  109. standard 4x4
  110. Short rear axle ratio for Cossie 2wd
  111. RS500 Who were when and rip
  112. 4x4 cossie crank sensor
  113. any info on factory immobiliser alarm 4x4 cossie
  114. 2.9 xr4x4
  115. Radio on Sierra Sapphire GLX1.8
  116. Fuel Computer
  117. rs500 engine
  118. rough idle, flooded engine 2wd cossie
  119. Nikki's piccies
  120. tech essay forum???
  121. 4x4 sapp not starting
  122. aftermarket ECU crank trigger wheel
  123. Ignition advance curve
  124. which breather kit???
  125. RS500 turbo specs
  126. Oil Cooler - Where to fit?
  127. NO SPARK ON 4X4 COSSIE
  128. Best/easiest way to mount fuel press. and oil temp. sensor?
  129. oil warning light advice please
  130. Cos. Saff. Front Cals.
  131. 3bar map sensor problems
  132. please help ???? 4x4 cosworth stg 3
  133. max power with 2wd engine
  134. WANTED 200 BLOCK
  135. Air con on 4x4's??????
  136. 2wd Brakes help please.......
  137. yellow injectors
  138. cams and tuning...
  139. Cossie ISCV
  140. rs 500!!!!!!!!!!!!!
  141. owners manual
  142. Any Ideas????? HELP
  143. slack gearbox
  144. 2WD/4WD Cosworth turbo specs
  145. Rocker cover colours
  146. My Project
  147. a little advice needed
  148. My RS500 with new wheels, pics.
  149. 3dr cosworth for sale
  150. Sierra 2.9i 4x4 question....
  151. what is a big winged sump ?
  152. any ideas?
  153. RS500 side exit exhaust
  154. 4x4 sappy
  155. how easy to get 18" compo mo's on a 4x4 saff?
  156. lets see your 3 door then
  157. Pics of my car!
  158. Green top with T4???
  159. The old gold lady
  160. sierra coz 4x4 k reg £3200
  161. exhaust manifold
  162. Reconditioning 2wd Cos Rear Calipers
  163. 3dr Rear suspension for track day use. I need some help.
  164. 3 door prices
  165. Saff Cossie spec sheets and standard equipment
  166. moonstone 4x4 cosworth for sale
  167. 3Dr Throttle Cable
  168. T4 Alternator Drop Bracket
  169. 89 moonstone blue 2wd saff 350 bhp for sale
  170. Ratio air / petrol
  171. Clutch Question
  172. t5 gear ratios
  173. wanted 1 late spec 4x4 alloy (shark tooth)
  174. polished silver baileys recir d v for escort cossy or saph
  175. Facelift Dash
  176. What Fuel
  177. RS : Engine cranks but will no start
  178. noisy GRP A fuel pump
  179. central locking
  180. Combustion chamber volume
  181. 3 Dr Interior Leather retrim,,where?
  182. change colour? saph 2wd
  183. RS 500 splitters!
  184. induction kits for sale. aluminium air pipe/fittings & c
  185. 3door daily driver-is this possible?
  186. which spark plugs ?
  187. cracked block - what to do?
  188. Front spring 4x4 instead 4x2
  189. XR4x4 driveshaft in Cos 4x4-> engine & diff moving si
  190. rs 4 spoke cos 4x4
  191. blakc diamond
  192. 8v to 16v head
  193. clutch help
  194. Best Big Power Induction Filter
  195. differences between 2wd's and 4x4's
  196. Saff cosworth gauge pod
  197. track ( national day ) help !!
  198. Newbie might be getting a Cossie!
  199. TCA Poly Bushes
  200. Battery/Alternator problem
  201. Boost controls?
  202. Saph gauges
  203. Engine revs dying when pulling up to stop on 4x4 Saff
  204. Advice on buying a 3dr Cosworth
  205. Thinking of buying a Cosworth engine for project car, help!!
  206. cosworth poppin driveshaft
  207. Wiring Advice
  208. Smokin' & Leakin'
  209. Red 2wd Cossie...How Many???
  210. mint 3door/rs500 front recaro seats for sale
  211. Help needed timing a N/A Cossy motor with verniers
  212. help wanted
  213. Cosworth sierra Whale-tail Stolen from York
  214. collins chip stage 1
  215. 3DR WHEELS
  216. indicators not working on facelift Saff
  217. Crystal blue 2wd how many were made?
  218. Fire Extinguisher!
  219. WHAT's MY COSSY WORTH????
  220. TURBOPRICES ?
  221. door removal
  222. 3DR with only 54 km?!
  223. 304-R Rouse Sport Cosworth
  224. another saff!
  225. 4x4 3Dr Cossie Project (updated 25/02/05 new pics )
  226. 3door / rs 500
  227. cvh exaust
  228. 17'' alloys wanted
  229. Sierra Rs Cosworth 3DR like new!!
  230. black 2wd saph
  231. stainless water pipe where from?
  232. dash colours
  233. my new wheels
  234. Oil pumps
  235. spark plugs for cos now ngks are discontinued?
  236. any gains????
  237. slight cam rattle when cold
  238. PX , mint S2
  239. L 820 HGS. SILVER SAPPHIRE COSWORTH 4X4
  240. RS500/3dr Wheels
  241. Turbolag
  242. T3 turbo
  243. strange brake problem
  244. scorpian exhausts
  245. can i turn the boost up any???
  246. 205/50/15 tyres for sale
  247. RS500 plenum/8 injector kit
  248. stage three bits fitted and now no spark.
  249. 3dr breaking (maybe)
  250. is this suitable???????
