- Secs monitor
- 3DR cold start problem!!
- Front seat base sunk.
- Xr4i from Ibiza
- 1994 Sierra Sapphire Headlight Problem
- Holset Hy30 turbo
- Tyres for Standard Rims
- Sapphire leather door cards?
- Brake upgrade reccomends plz
- Breather Kit
- Centre window controls
- Speedo cable
- Not starting/fuel pump
- The age old Cossie Spark Plug debate
- Anyone got a leather arm rest for sale?
- Are these the correct Driveshafts?
- any one not using bosch 044 fuel pump?
- Ignition module
- Caliper Seal
- Sierra non abs master cylinder swap
- Gear knob problem
- Bouncing rev counter / red engine light on dash
- standard T3 & breather on stage 3?
- Engine management light
- 3dr problem with lights
- 225 50 15s on standard lattice rim
- 3 door sierra cosworth
- Looking for a T35 turbo
- RS500 style intercooler
- AB07 cam availability
- alternative injectors
- 215/40/17 tyres
- fog light surrounds
- cosworth problem
- Best Turbo for a Cosworth rally car
- HELP - What is this?
- Sierra saph cosworth T5 gearbox
- got my new rear bells and rotors
- 3dr cosworth hydrolic lifters need help!!!
- 2wd hub bearing dust covers - where from?
- Calibre vintage 17x8J et 35 fit brembo 4 pots
- CC of a 4x4 head
- EMS wheels like oz racing will they fit
- Fronst Strut Brace
- saph roof lining
- 4x4 Sapphire Cosworth won't start??
- Exhaust fumes in car ?
- Sapph rear bumper brackets
- Oil pressure gauge
- Bosch EV14 1000cc Injectors
- 500 with F40
- Cold idle
- Just got in with my 3 door
- Clutch & Chip
- Fuel problem cossie 4x4?
- 16x7 alloys out there?
- 3 door diff rebuild .
- New wheels for the 3 Door
- Cosworth fuel line tool
- Need Help for 1989 Sierra Coupe
- Wiring - Green signal wire
- Prop doughtnut 3Door cosworth
- What happened to white 3door E904 DTT ?
- Will 2wd calipers and discs fit onto a 4x4
- Compression ratio
- Sierra sapphire cosworth reg F211 BEC anyone no where it is?
- hubs help
- 7.5" diff rebuild
- Anyone help identify this chip?!
- Sharktooth centre caps
- Sierra saphire 2wd waste gate /screamer pipe
- Cosworth 4x4 flywheel
- Saph misfire after fitting Siemens 55lb
- Sapphire cosworth 4x4 registration K905 YKG
- 2wd cams into 4wd head
- Car escapes from the garage
- map sensor pipe diameter?
- magnecor 8.5mm red leads
- car not running right on cold start
- Saff front top mounts?
- PAS pump mount
- T5 front oil seal
- hydraulic clutch 4x4
- Brakes system
- Twin Scroll Pornography
- What Head gasket do I have on my YB COSWORTH??...Please help!!
- sierra 2wd 3d top strut bearing query
- 3 door/2wd suspension re-fit queries
- Toyo Sports
- cosworth 3 door temperature query
- Valve springs
- Can someone ID this loom
- Alloy radiator and RS500 cooler
- Tailgate badges
- Low boost
- Windows not winding up.
- Ybt cosworth full engine gasket set
- lowering springs
- MSD (usa) multispark ignition module
- Converting a sierra 5dr to 3dr
- Rs 500 sapphire splitters
- head bolt torque
- Fuel Pressure Regulator Kit Sierra Sapphire Cosworth 4x4 GGR1133
- New sunroof seals on Ebay
- sapphire cosworth rear bumper
- single gauge pod
- cg motorsport clutch?
- Misfire
- Worn antiroll bar droplinks
- Sapphire Cosworth brakes
- YB Water Pump
- federal rsr tyres
- Brakes
- Map sensor brackets 2 bar and 3 bar the same ?
- Cosworth fan loom diagram
- Starter problem?
- widest tyre on the rear of a saff with 6 deg beam
- High idle speed - sierra 2wd cosworth
- Braided hose
- ap 4pots
- T34 advice
- where did tabetha go?
- 4cyl tachometer on BOB
- Classic car engine problem
- What battery 2wd sapphire
- Stage 3 200 Block Cosworth Gasket Set Advice
- Sapphire temp gauge reading high
- Billet diff mount
- LHD Sierra 3DR
- 3dr won't run after cams/tappets change
- Head work on my 4x4
- tyre choice!!
- gaz coilovers
- Brake pipe routing pics
- sierra cosworth engine
- 4" Exhaust System
- Real or No Real??
- Brake- & fuel lines
- New tappets
- history of your car?
- Faulty temperature sensor on 2wd Sapphire
- GReddy boost controller setup
- Can I run a Pectel monitor on an L8 ECU?
- 4x4 starter motor
- Do mk3 escort steering wheels fit mk1 sierras?
- fuel pressure regulator options
- Spring clean for my Sapphire 2wd
- Total race spec 10/50 oil for 3dr Cosworth anygood!
- wideband lambda,what kit??
- saff door draft strip seals?
- 215/35/18 tyres , trouble finding some
- Tyre pressures for 18s
- Rear beam bush help
- T5 Box help
- Drive shaft help ASAP
- Granada/Scorpio vented calipers on SIERRA axle?
- Anyone running a YB on Omex ecu
- Fitting interior loom on a 3dr Cosworth??
- eBay cosworth wrc head bolts any one used them ?
- RS500 Intercooler mounting
- Stage 3 , what's next step up ?
- 3 door prices
- Had the saph out the week
- 2wd for pots to fit rears anybody done this ?
- Cosworth ABS sensors
- Has anyone fitted a 90amp granny cossie alternator ?
- Cosworth Inlet Support Bracket
- Transit Connect Starter fitted to my 3 Door
- My 2WD
- Rocker Gasket / Half Moons....
- Where to get a brand new 4x4 cossie PAS pump?
- Bearings
- Can you guess what it is?
- Cosworth flat spot 5000revs.
- sapphire cossy seat runners
- door card pad removal
- t5 gearbox
- 2wd and 4wd discs
- New splitter / Reg plates - finally
- fitting chip to l8 ecu
- 3 bar map sensor referb
- washer bottle level sensor
- t5 gearbox
- Spark Blowout..
- cosworth oil
- t3 banjo snapped
- What tyres for my Sapph?
- Saph front hub caliper mounts
- turbo heat shield 2wd
- Gauge mount in 2wd
- Bubbling window rubbers
- Cosworth cam cover
- Pic request for front ap's brake hose position
- Sierra MC / Servo options
- Cosworth windscreen, can I use a Ghia one?
- Are 3 door & Saff door mirrors the same?
- So i got uprated front driveshafts,can i use the new Joints
- Which clutch, organic or paddle?
- ARP Head bolts
- problem
- How many Cosworths left?
- Re-fitting saph door
- Cosworth misfire on boost after turbo rebuild.
- Best lowering springs 4wd sierra cosworth
- speedo information needed
- Back end photos please
- 2wd big oil sump
- Clutch problem
- would 2wd springs fit 4wd sierra cosworth
- 3dr door mirror switch wanted.....
- eBay cosworth alloy radiators .... Any good ?
- Saph rear windscreen seal
- t5 cossie box info needed
- 2wd cosworth heat shield
- Sierra 4x4 V6
- Sierra 4x4 V6
- Nice noises!
- Quick Vid of Launch Control on my 3 Door
- strut top mounts
- Fuel pump voltage ?
- 4x4 water pump replacement
- Bd15 cam settings??
- In need of some good gauges for me cozzy ??
- Magnatec 5w30 fully synthetic?
- Oz monte wheels
- T4 with Grays Cams for fast road
- T5 bellhousing torq size
- Just ordered some waterless coolant
- bosch 355s
- Recommend me some rear tyres for my saff
- 3dr indicator clips
- 3 door and Saph hubs
- 4x4 header tank
- cosworth exhaust downpipe temps
- Problem with water pump 4x4
- 4x4 to 2wd front suspension problem with my saph
- JBW OS3 wheels
- cosworth piston identification ..........
- sierra 2.3d engine swap
- 3 bar map sensors
- cam cover leaks! H E L P !
- bell housing bolts
- New cosworth t34 turbo headache
- 2wd standard turbo damper setting?
- Sealer
- Oil leaks
- Dilemma
