PAS pump mount
PAS pump mount
Should there be a gasket between the power steering pump mount and the block where the old pinto mechanical fuel pump is run from, can't find a gasket for it in the set, don't want to put it on this now incase it leaks, took the engine apart over 2 years ago and cent remember if there should be one there , cheers
Cool cheers , didn't know if the hole was blocked off inside with the cossie blocks , guess I'll make a gasket then , cheers !
rsguy
44
29-09-2015 03:29 PM
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
