PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
  1. cosworth 2wd oil pump
  2. lambda/HEGO sensor on MSD closed loop on late cossie 4x4
  3. Koni Shocks
  4. Single wiper conversion
  5. Sierra Center Prop donut problem
  6. speedo cable help!!
  7. sierra part name?
  8. rear beam bushes removal!....help
  9. RS500 8 injector loom.
  10. Help please
  11. Proalloy VS airtek intercooler ???
  12. Nice gear lever?
  13. amal R port jetting
  14. Bosch fuel pump
  15. Saff cosworth headlights
  16. cam identification - no markings
  17. sierra scrappage shame
  18. setup
  19. Saff cossie head lining cloth.
  20. My 3 Door Cosworth out of the garage
  21. T5 Borg Warner gaskets???
  22. 3dr sunroof
  23. brake/fuel pipes
  24. Valve stem seals
  25. Looking for a 2wd throttle body
  26. Headlamp issue. Familiar to anyone??????
  27. GP A saphhire
  28. oppliger big tooth kit
  29. Won't start, coilpack making a noise
  30. Anyone have a step by step guide on changing the rear diff mount
  31. angled distributor
  32. front splitter
  33. How to - Spot 'Gen' RS
  34. Alternator Drop Link
  35. standard 2wd saff made 222bhp ;-)
  36. anybody have a upgrade or replacement doughnut??
  37. t34 or t38
  38. Fuel Line Clips
  39. track control arms
  40. Cossie rear prop, staked or circlipped Universal Joint?
  41. dash display problem sapphire cosworth
  42. lowering springs wanted!!
  43. Tabetha new gauges
  44. Airbox or Cone filter, interesting!!!!!!!!
  45. First time project--1990Sierra V6
  46. Saff Cos/Esc Cos tca's difference
  47. Nsf drive shaft sapph 4x4
  48. Fuses
  49. Radiator
  50. Sapphire wheel on a mk2 Sierra
  51. What size...........
  52. does any1 know J7YDL magenta saph
  53. standard stereo
  54. Two questions about G reg '89 2.9 xr4x4
  55. Cosworth 4x4 spark plugs
  56. About GPA coils
  57. Both ABS lights come on when braking
  58. Sapphire advise
  59. Paint code
  60. closed loop
  61. ECU main live?
  62. main cap's
  63. do you think this is the same as a t5 realease bearing arm
  64. wat turbo replacement
  65. Rolling road
  66. Sway Bar - Rear
  67. bottom end
  68. l8 ecu
  69. 3DR std track rods or adjustable for raod use??...
  70. My new rs500 front splliter(Updated now with better pics + others)
  71. 4x4 type 9 gearbox power range
  72. Pre-Pump Fuel Filter
  73. Alloys + Shocks for a 2WD Sapph
  74. cosworth 2wd & 4WD STARTER MOTORS THE SAME?
  75. RS500 thermostat housing
  76. xr4i cossie engine
  77. poly bushes?good or bad?
  78. L8 ECU how can you tell what diff from l1 l6 pics
  79. 275ib springs on the front?
  80. 1000 ccm injectors
  81. cheap 3dr bumper
  82. Rear beam/wishbones removal?
  83. Info Needed, Thread Size on Cosworth Block (Breather Port)
  84. standard sapphy speakers
  85. Wiseco Pistons
  86. Wat use rekon
  87. RS500 inlet or wrc 8 injector set up parts
  88. whats the differance between inlet and exhaust cam?
  89. What anti freeze?
  90. Another ABS sensor question
  91. anyone know any history on D994 KBO black 3 door
  92. ABS sensors?
  93. Whats your favourite cossie videos? Heres a couple of mine
  94. RS500 £40k.....i`ll have two please.....
  95. Reference pics of YB engines
  96. cossy diff and gearbox into xr4x4
  97. Sapphire seats
  98. will not boost with amal valve conected?
  99. Anti-lag Simple?
  100. Turbo Boost....More Please!
  101. saph fuse box
  102. T34.55 on a stage 3 3dr Cossie . Is it worth fitting it?
  103. sierra part numbers!
  104. ABS faults on 4x4 overheated??
  105. bushings
  106. pectel board???
  107. cold start
  108. how low is your saff??
  109. What is this part called in english
  110. is my skocks f**ked
  111. Centre consol wireing
  112. silver box in pass footwell?
  113. Quick vid of my XR4Ti
  114. steering play on a sapphire!!! Pics now!!!!!!!!!!
  115. Pics of Saphs with mudflaps.
  116. front arb & tca bushes
  117. water leak under fuse box?
  118. To Rouse or not to Rouse that is the question?
  119. brake issues
  120. Beam mount removal?
  121. Offset Sierra Cosworth
  122. diff advise
  123. anodising pace intercooler and rad
  124. steering judder when stationary??
  125. Paddle clutch re-line
  126. bayjoo springs
  127. Which Matt Lewis?
  128. door mouldings
  129. Fitting side mount bucket seats
  130. Any tips on removing crank pully n gear?
  131. T34, question
  132. L8 ecu with all msd toys
  133. Cam belt cover interchangeable?
  134. T5 Borg Warner 5th pinion
  135. Spring "thingies"
  136. Show me your magenta saffs wearing ambers!
  137. is this a rs500 part?
  138. xmas tree rear lights
  139. Anyone know anything bout my Sapphire?
  140. Window rubbers
  141. torque settings for trailing arms etc?
  142. Brake judder
  143. headlight condensation??
  144. K Reg Granada 2.9 4x4 - Cosworth compatibility?
  145. 2wd Rocker Cover - Refurb and re-painting
  146. Fastest Cossie on 1/4 mile track?
  147. S.E.C.S. Monitor
  148. Rear Brakes
  149. 4x4 Saff wheel question
  150. 4x4 inlet
  151. Inside front turret dimensions?
  152. Bulkhead Sound deadening?
  153. standard 2wd sapphire cossy
  154. where to get a new heated front screen in a sapphire cosworth needed!!!!
  155. 2WD cosworth front shocks
  156. 2wd saph rear tyre sizes?
  157. Where to get a pectel board for L8 ecu?
  158. Do I change my Subaru STI for a Cosworth
  159. what engine oil
  160. 4x4 springs
  161. my new three door cosworth !
  162. What oils? (transmission)
  163. Where to place Gauges?
  164. Vacuum hose adaptor
  165. LSD's
  166. looking for a pic
  167. Throttle control sensor
  168. Fittings to setup Bosch 044
  169. Sapphire Cosworth rear antiroll bar
  170. throttle cable 2wd?
  171. removing door glass on a sapphire??
  172. Bonnet Struts
  173. Header tank 2wd
  174. My 1st Cossie....................possibly!
  175. Original loom?
  176. Big RS500 question, reply please ???
  177. Rouse Rear Spoiler
  178. Hardy coupling, hardy joint spicer
  179. coilovers on a 4x4 saff
  180. Running in swarf
  181. Best head gasket for cossie YB
  182. ANYONE in the sheffield or yorkshire area????
  183. 4x4 saph gearbox???
  184. front strut brace
  185. Bonnet vents
  186. Power Steering Pumps
  187. rear strut brace
  188. Heatshield Repair
  189. do Saph rear door windows fit mk2 Sierras?
  190. sierra engines
  191. Anyone know anything about these brakes?
  192. L8
  193. Cosworth Top Mount Options
  194. Drop Bracket Fitting Guide
  195. Help with saff cossie head lining.
  196. Hid's Any Recommedations
  197. 90 cosworth 4x4 CAR STEREO
  198. oil
  199. Saph Cossie Police Cars, 1 more found 05/09/11, well sort off
  200. Bumper Mounts Rotted. Help!!!!
  201. rs500 build num badge
  202. Sierra Cosworth rwd Ignition Wiring
  203. sideskirt clips
  204. Tips for removing rear glass without breaking?
  205. Low revs miss-fire/hesitation
  206. strut brace / heat shield
  207. Starting issues - 03/03
  208. th2/rl7/rondell 122
  209. Rad Bolts
  210. Cutting out
  211. New VC from Bara Motorsports behaves strange??
  212. RS500 radio
  213. Fuel pipes Help
  214. CO Issues..
  215. suspension change
  216. K&N group A induction filter
  217. 3dr can belt cover original
  218. Centre Console and Wiper help
  219. Does anyone know where K549 SRK is, and who owns it now?
  220. 4x4 rear 18mm antiroll bar brackets
  221. Lumenition Air fuel ratio meter
  222. 2wd Saph engine loom help!
  223. 4x4 sapph with centre box removed
  224. wanted-glove box clip
  225. will et 40 17"s fit saff?
  226. dump valve
  227. Difference in fuel rails
  228. lamda sensor position ???????
  229. Wheel spacers for bigger brakes
  230. Thread size fuel pump
  231. Fuel pump anti vibration mounts?
  232. 4x4 saph clutch????
  233. Oil level problem 4x4
  234. quick question re. Lattice wheels
  235. Gas flowed throttlebody?
  236. Carlooms UK
  237. gt3071r
  238. how much will a std 4x4 back diff take
  239. 4x4 coilover question
  240. mongoose zaust
  241. standard 4WD gearbox mount where to buy
  242. what front brake discs?
  243. Wheel offset
  244. Alternator/dash issues?
  245. 4wd rear calipers and discs on a 3 dr
  246. Which spark plugs for 4x4 Cosworth
  247. 3dr Cosworth front splitter/rubber stone gaurd; same as Saff?
  248. cossie sensor kits
  249. 28mm driveshaft (rear)
  250. f750ffm
