4x4 rear 18mm antiroll bar brackets
oohmamama
Does anyone know where I can get a pair of brackets for rear anti roll bar 18mm for my sapphire cossie 4x4?
Are there other ford models which have identical brackets which I could use?
thanks for your help
The 2wd 16mm rear arb brackets are the same as the 18mm ones, as are the 22mm escos ones, they are pretty universal on the sierra.
I would contact NYRS, I used the original 16mm arb brackets on my 22mm adjustable rear arb on my 2wd.
oohmamama
That's Ok Steve. Thanks .
Tabetha: who/where are NYRS? Do I understand you correctly, the models you mentioned use identical metal brackets but different size bushes to suit different diameter ARBs? Thanks
NYRS, = North Yorshire Rally spares, aka Paul off of PF, very reliable person to deal with, good prices too.
I am 100% certain the brackets were the same, just as you say different size bushes, 16mm arb on 2wd(rear) amd 18mm 4wd, escos were 22mm.
09-10-2015 07:38 PM
james kiely
28-08-2015 08:58 PM
lockie
31-07-2015 10:03 PM
Graceland
31-07-2015 10:34 AM
