cold start
Old 22-02-2010 | 06:33 PM
botters's Avatar
botters
competant bodger
Default cold start
hi just bought a 3 door its got a 4x4 engine loom ecu etc... in it its running great just doesnt seem to have any sort of cold start on it, when i first start i have to hold it about 2k rpm for a minute or so otherwise its very spluttery and cuts out but once its been running a couple of minutes it fine, what should i check first? its been stood for pretty much 2 years having only covered 342 miles in that time its had new plugs by the way
Old 22-02-2010 | 06:45 PM
MAD Ade's Avatar
MAD Ade
Sounds like the ISCV isn't working. Remove it and clean the bit that pretrudes into the manifold with brake cleaner or similar solvent, they get gunked up over time and fail, especially if parked up for some time.
Old 22-02-2010 | 07:36 PM
botters's Avatar
botters
competant bodger
cheers mate ill give it a go tommorow would that cause the management light to stay on for a minute or too also? as it intermittently does that as well allthough in past 3 days it has been started/ stopped a lot while ive been moving it round the workshop so could be summat like that i know even a lot of modern cars get confused when doing this at work lol!
Old 23-02-2010 | 06:03 PM
As it's been stood I would invest in a new fuel filter, as well as fresh fuel, give it a few miles to get used to being used again first, might settle down, then check the CO according to the chip maker, confused as to why it has a management light working as didn't think L8(4wd) had this feature ?
Old 23-02-2010 | 09:15 PM
botters's Avatar
botters
competant bodger
im going to give it a full service cambelt etc.. this weekend anyway mate before i take it on the road then my plan was to be gentle for first hundred miles or so anyway then its going to motorsport developments for a full checkover as for management light its gone off now going to check the ecu as im just presuming its 4wd as the car has 4wd, 4wd engine and 4wd loom
Old 24-02-2010 | 07:58 AM
A fuelling check is a good idea, on any car when modded, at least to start with, if it hasn't got a rewired fan loom and a rewired fuel pump loom, I would do these first, as they need doing anyway due to age/deterioration of the wiring, just save you a little bit if you do them first.
Old 25-02-2010 | 01:17 AM
botters's Avatar
botters
competant bodger
cheers mate they are also on my to do list before she goes on the road
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
xrmalin
13-09-2015 06:52 PM
stevierob
07-09-2015 07:09 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
gingeRS
04-09-2015 06:29 PM
Quick Reply: cold start
