Difference in fuel rails
03-02-2010, 12:40 PM
What's the differences between 2wd and 4wd fuel lines?
03-02-2010, 03:28 PM
2wd has a pipe between fuel rail and fuel pressure regulator.
4wd doesn't
there may be more i'm sure others will be here soon
edit: i read that wrong didn't i (fail) thought it said fuel rail
Reason: fail
03-02-2010, 04:25 PM
4x4 has different connections IIRC? Also has that curly section in the return line lol
PS do you mean rails or lines? The thread title is rails, but the first post is about lines?
03-02-2010, 04:36 PM
Quote:
Originally Posted by
ozmk1cos
It wasn't me being silly then they is something to confuse me.
03-02-2010, 06:12 PM
As said main difference is the attachment of the pressure reg, being by pipe on 2wd and bolted to the end section on 4wd.
03-02-2010, 06:18 PM
can you use a 2wd rail on a 4x4 inlet ?
03-02-2010, 10:08 PM
Woops
its meant to be rail. I have just got a 4wd inlet with no rail on and wanted to know if I can use my original one.
04-02-2010, 12:30 AM
Mounting lugs for fitting the rail to the inlet manifold are diffrent if i recall between 2wd and 4x4 .
04-02-2010, 06:54 AM
ozmk1cos
Woops
No, lugs on 4 wd inlet are not in same place as 2wd inlet. You can't fit straight.
Regards.
Claude
JK12
33
26-04-2021 12:09 PM
Cossiesteve
Ford Escort RS Cosworth
17-09-2015 12:37 PM
STAFFY OWNER
13-09-2015 08:59 PM
mike elsome
Ford Range
09-09-2015 05:05 PM
kevin36
08-09-2015 12:23 PM
