does anybody know how to stop them steaming up on the inside, had them to bits 2day, clean them and the seals, and they are still steaming up!
cheers shaun
I put mine on with my fave stuff, loctite 5900 sealant, ZERO condensation, but I also have drilled two 1/2" holes in shell, condensation forms with rapid temp changes, by having these holes the temps are much closer, so when switching off the light it doesn't have a sudden temp change, as already cooler than normal in there.
Had same problem on me astra front indicator, three 4mm holes in bottom 100% cure, although in this case it was more likely a leak of water into them, despite being new.
