Anti-lag Simple?
Anti-lag Simple?
hi,
I borrowed this from a friend on another site.
On Cosworth Management for mild antilag (0psi at idle) you do not need ANY special shaft, ANY throttle body mods and a normal ISCV. You will need a P8 or similar board equipped ECU.
For aggressive antilag (positive boost on idle) you need a Maram shaft (which has a higher heat rating and can take the extra energy created by being on boost all the time) turbo and an enlarged Antilag hole and a special modified ISCV to flow more air into the inlet. You will need a P8 or similar board equipped ECU.
Is it as simple to have mild Anti-lag this easily?! Is it an additional chip that can be fitted to the board or will a whole new chip be required?
Many thanks,
Shane
Many thanks,
Shane
does mild anti lag make much difference between gearchanges,i was thinking about using it.Its the noise that concerns me though.How noisy is mild anti lag ?
Are bless ... When we was setting up mine at James Max his dog was sniffing round' "Hmmm what they up too" then all of a sudden..... BANG BANG BANGBANG, she shot off like an exocet missile poor old girl hence to say, she don't like cossies any more
unsafe with big flames hanging out the back
cossie fan (unluckerly)
i have anti lag and launch control on mine through my autronics anti lag is a bit of a gimik on the road to be honest i just feel like a twat with everyone thinking whats all that noise that cars makeing lol but launch control is very good
Isn't AL illegal to use ?, I can understand peeps getting launch control if they want it but not AL, still it's thier choice, just seems a gimmick for gimmicks sake.
launch control is very good i can get mine of the line much faster with it than without! but anti lag ill give u that one not much point on the road its more of a showing off thing
Serious exhaust temps, if anything other than mild will need modded turbo shaft(maram).
LC I could understand, electronic control is much quicker than human, but that's well on it's way for me now, just a(free) download away.
