4x4 inlet
Ive got a 4x4 inlet cover in the garage with a reyland 14mm spacer.
I was looking at it compared to the wank 2wd one which is fitted, im wondering what the options are...
Is it worth fitting the spacer to the 2wd as im lazy ?![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Can i fit the cover to the 2wd bottom part so i can keep the rail etc ?
whats the score with the throttle body as it doesnt look like it will fit with the 2wd tps ?
cheers paul
cheers paul
cheers matt, im always up for a cheap option ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
is the only difference between regs, 2wd is joined by pipe & 4x4 has gasket ?
is the mounting of the rail no different then ?
Is it the 4x4 fuel rail that has the pressure regulator bolted directly to it rather than through a small bit of hose?
Sorry, forget that, Ive just had a closer look at the pics etc!! and answered my own question!
ive now got the fuel rail and reg of a 4x4 thanks to ronnie amis, top bloke
i know need to order some cometic gaskets to get it all bolted together, once fitted i know its advisable to get fueling checked etc but will it run fine or will it be all over the place ?
Ive now got a 4x4 inlet, 14mm space, 4x4 rail & regulator.
The rail and reg has the original ford rubber fuel hoses still connected, will i beable to disconected the 2wd bits and connect these into the inner wing fuel fittings or will it need modding ?
![](http://i119.photobucket.com/albums/o159/paulsgreyrs/001-32.jpg)
started on this today as i had a few hours after work, was a bit of a bitch to get the 2wd bits off, offered up the 4x4 rail and reg and realised it is atchualy much easier to use the 2wd bits.
I need to cut the back bracket slightly to it can be bent a fraction then make a little bracket up for the front one, will get some pics up tomorrow
07-10-2015 12:56 PM
Johnny Knoxville
30-09-2015 07:21 AM
