Sapphire Cosworth rear antiroll bar
V6 Poisoned
Hi everyone,
I have a question - from where can I buy a Sapphire Cosworth antiroll bar? I don't have one on my car - because my rear axle is coming from a 2.0 RWD XR4i (the axle from the 2.8i XR -I know thar the early XR's have a thin bar- was bought by someone else before I was aware that the car was dismanteled and sold piece by piece). What else do I need in order to fit the bar on my rear axle?
The sapphy arb is much shorter as you know, you will need to weld on brackets to hold clamps/bushes, then depending on which rear arms you are using will need to have fittings on the inner edges, xr4i arms are as you know on the outer edge, so might need to weld on some points.
lukeeboy149
22-08-2015 04:29 PM
