- Screws _£10!!!!!!!!!!!!!!!!!!!1
- cut out on boost
- Arch Rolling.
- breaking a 2wd cozzy in north east area?
- 4x4 cossie engine removal
- HELP, Oil Pressure Guage on 4x4 saff
- Where to go for the best Cylinder head?
- 9x16 215/40 ET35 on Sapphire?
- bonnet vents...
- 3-door / RS500 genuine parts
- A.R.P STUD & NUT KIT HELP!!!!!!!!!!!!
- 4X4 SAPPHIRE TURBO NEW OR NEWLY RECONDITIONED-HOW MUCH?
- Question
- Front window glass
- 4WD cossie heads how much?
- BD10s
- Quaife ATB for 2WD Saff
- Gearbox or Propshaft?
- Tyre Pressure
- Whats this worth?
- how many crystal blue sapphire's
- rs 500 intercooler
- Saphire electric sunroof, what's needed?
- Hi every one some help please
- 3 Door Speedo Cable
- 215/40W16 or 215/45W16 for my Sapphire
- Digital clock light on dash
- changing drive shaft gaitor - how?
- Need BHP!
- The Ultimate Cosworth Inlet Manifold?
- sierra chassis numbers????????????????????????????
- lights flicker???!!
- urgent help, please:-(
- Not right at high revs
- north east tuners
- Recon Rocker cover
- Stage one chips
- ? How many Ebony black sapphire cossies?
- RS500 restoration
- cosworth 4x4 air con
- if only i knew how 2 use my head
- Buying parts overseas - Canada
- Nothings simple
- oil change
- sapph 4x4 ecu
- orig. Sapphire 4wd wheels - claen-up??
- ESCOS AND SAPPH 4X4 Koni suspension
- Clutch Cable
- rs 500 / 3door lumbar support pads
- Compression on Cometic Head gasket????
- service history
- more oil than petrol???!!!
- measurements
- Group A K&N Cone
- Steering Rack - Who to use for reconditioning
- how low can i go
- water injection!
- Oil pressure
- M.P.G.
- 3 door question...
- Front prop shaft
- 3dr gear knobs!
- High Comp? PLEEEEEEASE help
- bumper pics
- what colours did the late spec saph 4x4 come in?????
- Standard Pistons?
- Saff Headlights
- wanted rs 500 front splitter
- cosworth interior on ebay
- boost gauge pod
- side skirts
- Adjustable Boost?
- what horse power should i expect
- Amal valves
- massitaliy vt5r's
- Temp gauge stopped working ?
- dropped to the floor
- cossie sus on 1,8LX
- What Clutch and where from
- ne one on here?
- Updating S.E.C.S Monitor
- 4X4 COLLINS SUPERCHIP C/W MOTHER BOARD 4 SALE
- help
- Is a cossie pedal box the same as boggo sierra ?
- 2wd Gearbox Problems
- 4x4?
- Wanted- Sapphire, preferably 1.8 Model
- SMITS CAR!!!!!!!!!!!!!!!!!!!!!!!!
- wot does YB stand for
- 3dr Side skirt removal
- Saff Electric Sunroof
- brakes
- Bit of troubhle with the saff....
- WANTED: 2.0 PINTO A-D Reg.
- Bumper mounts ( Sapphire )
- cosworth repsol
- yellows??
- Whats your views on Castle Performance
- Best looking wheels on Sapphire Cosworth???
- 3door wheel size
- SAPPHIRE FRONT BUMPER BRACKETS??
- body work needed
- whats the best exhaust?
- Diff and rear axle
- Best route for amp power lead??
- How can i rectify bore washing ?
- well lane?
- couple of questions
- backing of the boost using amal valve
- S/Steel intercooler pipe cold side dump valve (found one)
- RS 500
- buying advise
- Have a stab at how many miles this YB has done.....
- cosworth 4x4 springs
- gearbox oil.
- Anyone got any pics of sapphire with restored underside?
- 18in compo mo on a saph....
- escort cosworth rims on a three door
- Overfuelling/running rough
- Cossie boost characteristics
- wont change down?
- SIERRA COSSIE AUX WARNING (LIGHT FAILURE) DISPLAY
- Saf cossy courtesy lamps faulty, any ideas?
- t35 turbos
- breather systems
- changing rear shocks on 3 door
- HIGH COMP?
- How many sportscar whas made on 3dr cosworth
- Where can i buy
- Help identifying turbo
- engine firers
- light blues or dark greens can u use the same chip
- clutch help
- How do you change valve stem oil seals on a 3dr ?
- Changing springs
- WHAT DO I NEED?
- Head gasket problems :(
- Slight miss fire
- Oily plug on cyl #2
- loss of power
- Standard actuator
- Cossie Brake Problem
- Boost?
- 4x4 gearbox,diff and transfer box oil, which??!!!
- 3d Cosworth, wheels/tyre-size...
- Saff foglight prob
- call me dumb, but
- Best way to clean me cossie engine bay ?
- wanted cosworth cam cover
- Head Thickness
- AP Paddle Clutch
- How can i tell........
- Focus RS Brakes
- 4X4 HEAD
- 4x4 wheel offset....
- BREMBO 4 POTS
- Whats the best oil to use?
- Piston Querry
- T34 Vs T3
- pic request please
- Cosworth Racing or Mahle???????
- How many times has your car.....
- Swirl pot problem
- 3DR Classic Car Insurance And Extensive Power Upgrade
- No manufacturers warranty??.......
- How many miles has you're Sierra Cossie done?
- 1991 H 4X4 SAPHIRE FOR SALE.
- Oil pump querry???
- 3DR BARE HEAD WANTED
- differential 2wd cossie
- Radtec Rs500 i/cooler,hose too small,help please.
- Finally.........
- SAPPHIRE DOOR MOULDINGS AND DOOR WINDOW RUBBERS
- camber more on one wheel
- Flames
- 4x4 spoiler
- 92 SPEC / 93 SPEC??
- How much boost
- 3 Door / 2WD diffs
- Diff, Axle, Prop How Much ????
- Diff, Axle, Prop, How Much ??
- BD10's
- Clutch Release Bearing Gone?
- Block Swap HELP !!
- 2wd koni converted coilovers
- 2WD Saff g/box?
- water level on alloy tank
- v6 24v 3dr cosworth
- PARTS CD WANTED FOR RS500
- RS500 Down Pipe
- saph rear windows
- What plugs for stage 3
- RS500 rear suspension mounts
- INFO ON 2 COSWORTH,S
- D212 KKR 3 door cossie, anyone know where she is now ??
- Cossie AIR Filter, Which...............
- What benefit upgrading from 4x4 to RS500 i/cooler ?
- 3/door side strips,remanufatured?
- what causes over fueling
- Removing the rubber strips from side of 3 door.....
- standard air box drilled or not?
- pipes or hoses(opinions whats best sierra 4x4)
- My strange intercooler!
- Crystal blue
- Does anyone run coilovers
- insurance company for Modified RS500
- spluttering........HELP!!!!!!!!!
- sooty plugs
- tyre preasures and other things
- E453CGN
- Anyone own J245 ENW ?
- Cossybrom ZOO Motorsport !! Tried and Tested
- Timing belt question.....
- Are we ashamed to be driving Sierras ? ? ? ?
- AR.48 og AR.63
- HELP WANTED IS IT POSSIBLE TO REMOVE POWER STEERING FROM 4X4
- springs for 4x4
- Filters
- 4x4 koni susp
- Apexi AFC
- Spring rates for front of 2wd Sapphire Cosworth
- oil cooler
- Gasket choice !! Help !!!
- p/steering cooler pipe
- Dump valves
- Turbo Heat
- 205 block
- 2wd Saffy Radiator
- Boost
- Sierra RS, and RS500 spares and body parts
- boost
- octane booster
- north east body shop
- AP racing calipers
- lowerin springs
- lowered 4x4 cosworth
- Koni's or gaz coilovers
- 4x4 saph coolant and anc samco hoses
- 500 question
- 0-60 Time For a 3 Door 330BHP Conversion?
- grey injectors
- anyone know how much these cost at all ?
- HELP
- Splitters
- who is this?
- 2wd cosworth windscreen
- I've fallen in love
- chassis no?
- 2wd rear brake wear
