pipes or hoses(opinions whats best sierra 4x4)
Wanna hear the truth now.All in mine car are samcos,been told should be more flexible??Then somebody says,if you put pipe from t4 to intercooler you will have faster moment and i also now spec r doing pipe for intercooler to throttlebody,someone using them some dont,i am f..king confused.please tell me
Regards Alex
Regards Alex
if you use a more solid hose you will lose no pressure ! if the hoses are soft they can expand and use pressure .
i had all polished alloy ones made for my renault 5 turbo , i didnt really notice any difference but i never split another hose after having them made !!!
im using samcos on my 2wd and i personally think they will be fine .
they are about 3/4 of an inch wide , and instead of having a little screw to tighten them , they have a half inch bolt that goes thru a bar on the other side , which works basicly the same as a jubilee but a hell of a lot tighter .
Phil,i tried a RS500 throttle body side hose and at 34psi kept blowing it off until i used proper clips..but that caused it to split around the dump valve take off No probs with the samcos
Jeebus
saying that my throttle-body side hose is just like an rs500 but has a smooth finish and a part number stamped into it!? whereas my compressor side is a normal cloth texture finish!
very odd!
mines using ford jubilee clips and they actually seem very strong, but now everythings out its all going to have proper bling clips when rebuilt!
very odd!
