Head Thickness
04-02-2004, 06:08 PM
Head Thickness
What is the std head thicness for a 4x4 head
What is the minimum thickness it can be before it is rubish
(head thickness between top and bottom mating serfaces)
Thanks
04-02-2004, 08:08 PM
138.68mm between mating faces.
04-02-2004, 08:33 PM
Is that std or the minimum ???
05-02-2004, 07:36 AM
05-02-2004, 10:41 PM
So once the head thickness gets to 138.68 mil then its rubish and only good for the bin
Is this the same for all heads 2wd & 4x4 ?
06-02-2004, 12:38 AM
once it gets to that thickness stick it on ebay as a n/a cossie head
06-02-2004, 01:25 AM
either sell it or stick a set of low comp pistons in it.
06-02-2004, 06:43 AM
Or use a 'thick' Cometic gasket...
06-02-2004, 06:29 PM
So if you use low comps its not an issue ????
20-04-2004, 09:54 PM
mine is 137.8mm. there is no reason to bin the head. the only concern is the potential for valve to piston contact. lop some off the piston crown or get lowerc r pistons
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DAZZER
30-09-2015 08:43 PM
IainRS1700T
25-09-2015 06:44 AM
