changing drive shaft gaitor - how?
Testing the future
the rubber over the flexible joint (is it a proper cv joint?) on the outside of a front driveshaft on my 4x4 has split wide open.
i've got the replacement, and need to fit it tonight. can anyone shed some light onto how the joint comes apart to change it? i have got the proper rubber, not one of them spastic 2 part ones that you join together.
will be doing it at the same time as fitting new front dampers and poly bushes to the arb / tca, so will have the hubs off anyway.
cheeRS
cheeRS
All you need is a pair of circlip pliers (ones that open as you grip them). Remove the driveshaft from the car, then remove the metal clips that hold the boot onto the shaft. You can then pull the end off the driveshaft. Then use the circlip pliers to remove the retaining circlip for the spider. Pull this off the shaft, then remove the old boot and install the new one. Assembly is the reversal of removing LOL!
Testing the future
cheers wes
yep, it worked exactly like that. quite easy. only bugger was, theboot that i was supplied was completely wrong, so i've got to do it again
never mind, got new dampers and poly arb bushed fitted
JK12
33
26-04-2021 12:09 PM
