How do you change valve stem oil seals on a 3dr ?
Assuming u got the head off mate, you have to remove the valves first, then with either the proper pliers(makes it easier) or any pliers will do literally grip em and pull em off!! can sometimes be a biatch but dont worry as their coming off so doesnt matter if u damage them!!! Then to put new ones on you just need to get a couple long reach sockets that are the same size as the new seals(from memory inlet/zorst are different size) and tap them into place with a hammer gently
True, but when i first got my cossie and rebuilt the engine, and not knowing much about them sent the head off too have new guides fitted etc. Then when i was gonna put it back on the bloke who was helping who hadnt seen it b4 it went to them noticed how much it had been skimmed and basically it was skimmed too much by whoever had it before!! So was pretty useless. At end of day it was my/our fault for not realising but any decent machine shop should/would check things like that spec when doing something like fitting valve guides which cost me about £200
if your really really carfull you can always split them down the side with a sharp screwdriver, they come off a peice of piss then just be really carfull not to bend the top of the valve guides
like this!
like this!
thanks for the advice guys
i took the head to my local machine shop and they took them off
so that left me the job of lapping in the valves and fit the new seals, took me about 3 hrs
so now all i have to do it put all the bits back in the correct place
wish me luck ! cos i'm gunna need it
Ricky
Ricky
rsstav
Ford Focus RS Parts for Sale.
16-08-2015 08:38 AM
st220kyle
16
14-08-2015 06:13 AM
rsstav
11-08-2015 04:22 AM
