- poor castings
- Sierra Sapphire Problem
- quick question
- clips :/
- Interior Light
- How to turn up idle speed?? 3 door ?
- "fuel low" light blinking - anyone got an idea?
- Cossie 4x4 abs
- intercooler to plenum problem
- 4x4 geabox upgrade HELP?
- gearbox noise
- 4x4 rear diff oil?
- Value on 3dr please, looking to buy....
- 3Bar Map Sensor
- Anyone know how much these are new from fords?
- Accelerator stiff - is the cable going to fail?
- Cossie 4x4 brakes n abs
- HOLDING BOOST ON T3
- HELP ME PLEASE!!!!
- 4x4 front wheel bearing?
- what kind of power will i get
- 3dr inertia switch...
- Replacing sunroof with a carbon fibre panel
- Pros and Cons T4 turbo
- BEEN PLAYING WITH PC
- Saph going for it's MOT tomorrow
- Fitting/wiring Group A Coil on 4x4 Sapphire
- Relay
- 3 Door Rad fans wiring
- Anybody have a single Sapphire Cosworth wheel nut?
- Can I Connect a Lambda Sensor To My Car?
- sierra saphire rs cosworth
- cossie was on fire
- Brakes
- Does anyone know the answer to this? PLEASE!!!
- removing windscreen rubber from saph cosworth
- how much
- head thickness
- rockercover breather worth getting?
- Oil pump?
- Misfire at 3500
- Valve Springs
- Rocker cover gasket leak
- guibo joint/propshaft rubber 4x4
- Question about headcylinders
- Crank question
- Crank question
- 3 Door cos , wet carpet ????
- focus rs brembos on a cosy
- Wastegate external/internal?
- saffhire cossie rear suspension
- Under bonnet stickers
- exchange inlet RS500
- rousesport bodykit?
- Insurance at 20?
- T34 with no stage mods
- Best way for 350-380 BHP ?
- What springs to go for?
- ROYAL PURPLE OIL IS THE BEST
- anyone got mudflaps on their cossie
- original t3 4x4 turbo max boost
- Cometic or WRC head gasket ?
- Maintaining/re gassing Air Con on Sapphire Cossies
- cosworth oil
- Cylinder head cracked
- Discs welded on for eternity.... Brake upgrade advice pls
- fuel gauge probs
- Saff rear bumper removal?
- Where is the fuel pump relay located?
- Is it possible..............
- Fiberglass or carbon
- how much
- could someone tell me...
- Knock Knock!!
- Swirl pot question
- RS500 display and laps at Ford Fair
- abs and funny brakes.
- Advice on changing an ABS pump on a 4x4 saff...
- head gasket
- ABS Set up without ABS!
- 4x4 funny noise
- rear pads
- rocker breather threaded fitting, what size?
- How much boost at original 4x4 Sapphire
- 5 stud conversion
- wheels
- Exhaust manifold studs and nuts?
- Cooling problem -Think I may have over done it!
- Need a wiring diagram for Amal valve circuit on a 4x4 saph
- NOW GONE
- Ahmed Spec springs - who's got them fitted
- RS500 pics database
- whats the differences between 2wd + 4wd door mouldings?
- als question
- 4x4 sapphire sump gasket
- CENTRAL LOCKING MOTORS
- Problem With The ECU?
- 3door body
- next stage
- Heated windshield
- under carriage
- Soft brake pedal
- Performance cams?
- Gearknob/gearstick rattle
- ABS sensor problem.... Help please asap
- Search Suspension Kit for use in Rallye-Sport
- ABS LIGHT STAYING ON
- breaking near birmingham
- 7 x 17" OZ Ultraleggera on RWD Sierra??
- starting problem
- Turbo Noise
- where to for 909 parts?
- Speaker sizes...
- Any pics of Azev A wheels on 3dr cosworth
- Faulty temp gauge
- please can some 1 tell me ?
- 1/4 mile......?
- Fuel pressure regulator.
- Whats the best position in a Saph boot to mount a CD changer
- oil change 4 the diff
- HELP NEEDED BY TUNER, BOOST AN AMAL V
- saff boost jumping up and down any ideas ???????????????????
- Brake pad retaining pins? 2wd.
- Alternater had it?
- Saff rear speakers which ones?
- saff starting problems
- boot pop
- ABS....
- Piston damage?
- rev counter....
- Oil Catch tank
- Saff cossie 4x4 Problem
- The fella out of Faithless and his Saph Cossie
- Wheel alignment on 4x4 Saff
- What looks better?
- fog lights......
- Cam cap sequence?
- Removal of interior door card on Sapphire 4x4
- Backfire issue
- What do you think?
- Removal of centre console 4x4 sapphire.
- What sealant for 4x4 speedometer housing??
- Which non-homologated tyres ?
- turbo recon???
- Not Boosting Properly and Stuttering?
- Injectors
- Heated from Windscreen for a 3 door?
- Upgrading from T3 to T34, need some advice
- seals
- OE Black tank caps
- 17" alloys on Sierra Sapphire
- Turbo question / Oil filter question / oil breather question
- TPS (PF09)adjustment for MSD cloosed loop chip
- idle speed
- cosworth discs n calipers
- splutter
- in/ex valves
- top air vents
- fuel filter on sapph
- 3 door wiring harness
- racetech gauges help needed pls
- Side rear quarter window body profile - XR4-> 3Dr convert
- Timing marks?
- oil seperater????
- smokey
- Reason I've changed back to Zymol!
- need help please
- Cossie fuel pump rewiring
- lambda sensor position
- poly bushings
- rubber steering couplings are2wd and 4wd the same
- 4wd wheel bearings?
- Exhaust is so loud.
- Removing 2wd exhaust manifold.
- Rad fans?
- running car in
- 8,5x17 and 10x17 on a sierra ?
- Coil/spark problem
- roof cloth
- A few questions?
- few questions for ya
- Major Probs
- Aftermarket 2WD Fuel Pressure Regs?
- 4x4 and 2wd exhausts??
- removing middle box on cosworth?
- Which RS500 I/C is this?
- Will radiator cope??
- window seals
- What colour would you call this '88 cossie?
- B&M shifter problems....fouling on tunnel wall???
- 2wd-4x4 pistons
- Cossie 4x4 non start
- Fuel Pressure
- sierra 3 door
- Picture original Sierra 4x4 engine mount
- Cossie 4x4 drivers side front bottom suspension arm
- New brake disc's on a 3 door
- Focus RS wheels on a 4x4
- 3 Door fuse Box
- Bosch 044 Sock filter?
- t3 turbo damper
- Over Heating
- 3 Door stage 3 conversion.............How much boost??
- Can anyone help? I have a strange rattle.
- 3dr rubber steering coupling???
- disc conversion help?
- 2wd hubs
- What type dump valve for sierra cosworth??
- 3 bolt flange to fit a Cossie T3 Turbo, where to buy one ?
- boost gauge reads -0.1 BAR on tickover is this right?
- where have all the rs500 front bumpers gone?
- Seen 2 white 3 doors in two days round here!!!
- Tabetha - you rock.
- Alternator Wiring
- Saff Cosworth front splitter, what looks good?
- oil pressure guage adaptor
- Some questions for 500 BHP
- Rear arches
- INSTALL MSD CLOSED LOOP CHIP,please help!
- Torque settings and run in period
- air/fuel gauge installation
- 2wd propschaft
- 3dr cosworth silver stripe???
- 4x4 Saff Cossie Parts Help
- 3 Door Wheel Offset
- calling all 21 yr olds
- L6 Closed Loop?
- Analysis of compression test???
- EBC brakes
- V Band Flange Adaptor, Who supplies them?
- front bumper/grille mesh
- best polish and wax for my black 3dr
- MISSFIRE still here!!!
- cosworth fuel pump wiring
- Plenum Spacer 10mm
- Saff Cos 2wd rear brake calipers same as XR4X4?
- NOISY EXHAUST
- Has anyone fitted a aloy radiator and intercooler from E-Bay
- 4x4 cossie boost gauge
- recon turbo
- Sapphire 4x4 Cossie T3, 90* down pipe elbow ... quick Q
- Cossie 4x4 front wheel bearings
- what spoiler will suit my saphire ??
- i want dyno pics of every stage
- l8 ecu --- in 2wd
- Torque settings flywheel
- Amal valve and chip
- 3door help
- gotta be away of...
- rad intercooler combo
