- Oppliger gearbox
- Cossie problem, been set up...
- rear suspension question please
- FULLY passed the MOT!!
- Sierra Cosworth 2wd problem upgrading from stage 1 yellows to stage 3 dark greens
- 2wd clutch arm pivot
- saph cosworth overheating problem
- Ford sierra 1.6 cvh improvement
- Oil Temp and Pressure Sensor Placement - 2wd saph
- Helix paddle clutches
- 2ltr twin cam advice
- cossie running fault after i broke diff???????
- help! i need a cosworth 4x4 selector
- cosworth battery
- Carbon Roof / Bonnet for Sierra 3dr
- Turbo Coolant Pipes
- saff cos 4wd oil cooler pipe
- Happy as
- Gearbox choice ???????
- fitting saph cosworth front bumper to xr4x4
- Changing oil fluid MT75
- Moving a fuse box
- water temp sensor wire..???
- standard splitters
- assembling a 2wd turbo damper
- MAP sensor signal wire
- Swirl pots, worth it?
- Cloth interiors
- Stone Chip Advice
- Cosworth Lambda
- spotted my old cosworth
- 3 door windows
- ABS block brake pipe?
- Fuel Pump Rewire
- Clutch cable
- Removing injectors from fuel rail
- 18" wheels on a 3dr offset?
- What size hose for T34 turbo?
- t34 turbo
- AMAL valve
- 044 pump probs
- BBR Mogul
- Oil filter hitting against oil cooler sandwich plate?
- Longer wheels studs (group a?)
- black wheel nuts??
- 3 door turbo to exhaust manifold gasket
- where to get power steering pipes
- Engine and distributor timing
- Anyone bought one of these
- WIRING LOOM IN CAR( behind dash)
- max HP at 1.0 bar?
- how good are they
- nice looking 3dr
- 3dr Radio & Amp Model No. Required.
- Removing stud exhaust manifold cossie 4x4
- Dipstick
- my stage 3 saff cossie what clutch?
- spark plugs
- making a spit?
- p8 ecu with anti-lag pectel board..
- gr.A hubs - what shafts?
- cosworth breather advice needed
- Rusty strut top
- Left engine mount 4x4
- what discs and pads...arrrggh???
- Big spec Advice please
- Oil flow
- Fuel pump voltage ** update: disaster!!! **
- No Ignition lights - K reg Saph
- What colour wires for 2wd alternator?
- starter motor help!!!!!!!!
- my new saff cossy
- Sierra Cosworth 4x4 fuse Burning HELP Please
- Fuel and turbo gauge pic request
- what gasket set?
- sierra none cosworth suspension
- Replacement Injetor Seals
- is this the correct paint
- cosworth arms
- 2wd Manifold joint bolts
- Anyone know the rough weight of a sapph rear bumper?
- possible fuel problem again
- saff cos speaker sizes front and back
- 2wd alternator belts
- Concerns over Engine advantages chip?
- Proper pissed off
- noisey clutch components.
- 4x4 piston part numbers
- List of changes in order to convert std sierra to cossie
- saff fuel hoses?
- Head Bolt torque
- My old car G488 OUF
- my old cossie's
- Damaged pistons?
- msd coilpacks?
- Fly wheel balancing and lighting, worth it?
- throttle cable question
- 0w 40w mobil 1 in yb
- 2wd Pistons + 200 block
- Starting Problem - UPDATED POST AT BOTTOM, PLEASE HELP
- Heated windscreen...
- Help I have lost something
- Anyone had a new prop made for their Cossies?
- Help wanted
- What colour
- Cosworth oil change question...
- 2wd/4wd rear brake pads
- Rouse - Rs500 sapphire splitter...
- 2wd clutch cable longer or shorter than 4wd
- 3dr cossie rocker cover anyone??
- P8 instead of L8 in sapphire 4x4
- Tacho not reading correctly
- What pistons
- 3 door starting probs
- Sierra Spoiler screw covers
- Ecu cover....
- Replace 4x4 Sapphire Cam Belt
- GT30 sounds
- Fuel pipe size
- BD16 inlet cam
- Exhaust manifold swap
- Best flowing dump valve
- P8 pectel board functions
- replacing window motor
- 2wd saph over heating issue.
- turbo- wet floating v ball bearing
- Rs500 style sapphire front bumper....
- 3dr/2wd sapp cossie original 3 spoke steering wheel
- ECU plugs
- How do I fit rs500 fog grills?
- 18" wheels on a 3dr what offset
- Trouble fitting 2wd diff mount?!
- Wheels
- Cosworth 4wd ps pump/pulley
- bosch 044 non return valve is it needed.
- Swedish Plenum is this worth it ??
- what oils
- how much boost can i run on my t34???
- 4x4 cosworth
- Cosworth inlet manifold fittings
- EBAY FIND
- missing
- piston slap
- What next? GT30??
- Little electrical thing on my alternator
- Brake upgrade using standard calipers
- Headwork?
- Coilover spring helpers
- Group A gasket
- Sierra 4x4 Cosworth pre conversion planing [Help please]
- sierra cosworth workshop manual
- 2nd hand turbo advise
- cossie inlet manifolds
- My 2wd saph mapped Saturday by AFR Tuning
- Can someone clear this up for me??
- Brembo calpiers FRS
- saph cossie shells - going rate these days?
- Saph Cossie Pic Request
- Re-torque longstuds after warm engine?
- help me :)
- The Cossie returns to the road with pics
- picture request
- Greys
- Gearbox Mount
- How to secure turbo heatshield?
- turbo troubles?
- wrc multi layered head gasket
- Head gasket
- T5 Quick Shift
- Water cooled PAS reservoir
- ignition leads
- Show us your gauges
- Green or Black
- Brake lines
- tt t38 ut t38 driveable differences??
- Best slimeline fans for a cossie?
- spring help
- Track rod question
- splitter for saph
- c0 problem!
- 2wd diff on 4x4
- Head
- Fitting original ford bushes to rear beam.
- price of my 3dr ?
- Cam Cover Refurb
- cossie coilovers
- Fuel Pressure Regulator for a 4x4
- Sierra Estate Suspension Question....
- Rear Brake Dust guards
- P100 - Changing 2.8 to BOA Cozzie
- And todays fault is ......
- restoring underside of sapphire cosworth
- remote oil filter housing
- engine spec for fast road sierra 4x4 ???
- Good rear brake setup??
- Best way to leak test intercooler and hose s
- Cosworth 4x4 turbo for 450
- pts chips
- stage 3
- Engine bearings (ybb)
- 550-600bhp on a YB, whats needed?
- oil gauge
- Antone used these Alloy rads??????
- Phase 3 1.5 vs 2bar.....
- Misfire when hot
- Oil pump pressure release kit
- auto gearbox help!!!
- Help identifying windscreen
- 3 door brakes AGAIN
- gearbox help/advice
- RS500 rear fiberglass lip fitted
- sierra wiring and earth problems
- Boost control
- looking for a right hand 3dr door card
- 3 Door running problem
- calling your clutch advice!!!
- Mounting oil cooler to 3dr
- New wheels
- 4 pot rear brakes
- Blueflame exhausts
- Cossie boost 'cough'
- Wasted spark rev counter
- Gripper diffs
- Need Timesert fitted to cylinder head in Essex
- Saph beam onto an escos
- Won't rev above 3k
- a question about the sapphire shell?
- Dead mapsensor
- 2wd Gearbox
- 3dr Windscreen rubbers
- Hatch back/3dr parcel shelf
- how much do a set of 3dr rear ambers
- Anyone fitted Goodridge brake hoses?
- 2wd rear brake dust guards
- D404 ONM Sierra Cosworth any one know it?
- power steering pump
- Power steering fluid??
- RS Sapphire spares
- Battery Cables Length
- insurance time...could give me a heads up who your using?!?
- rebuilding yb lots of questions
- MSD closed loop
- Quick Question
- Where to get Amber 3 door front indicators from?
- Anyone NOT using a BOSCH fuel pump
- non abs master cylinder
- Problem trying to stage 3 cossie
- What power can a Cosworth 7" rear diff take ?
- Cosworth radiator
- Fuel filter/pump leaks
