PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
  1. Turbo water/oil lines
  2. 3 door cossie died
  3. XR4i Central cocking and electronic boot release??
  4. Sierra Tapered wheel bearings Help
  5. Headlining material WANTED
  6. Sierra Cosworth Standard Gear Knob Refurb.
  7. BD15+ Cams
  8. 4WD Loom on 2WD car
  9. fan comong on but not cooling
  10. Fuel pump wiring ( no 12v to pump )
  11. Rear lights
  12. T5 gearbox repair kit
  13. 3 door sierra boot lock
  14. Gear stick removal
  15. how heavy cossie head with manifolds and turbo
  16. Sierra Dashboard
  17. 2wd Cosworth pivot
  18. Difference 2wd sapph hubs and 3dr hubs
  19. Oil filter relocation
  20. aftermarket brake bias pedal box
  21. 4x4 starter
  22. Anal valve
  23. Sierra roof skin swap! any threads on it ?
  24. 4x4 crank pulley on 2wd...
  25. 3 door cosworth headlights
  26. spark plugs ngk or denso?????
  27. What head on sierra 4x4 front propshaft flange bolts
  28. In tank fuel pump upgrade needed for 24v v6
  29. turbosport experience ???
  30. Cylinder Head Bolts
  31. Thoughts!!!
  32. Cosworth cross members difference?
  33. Saff sideskirt clip position.
  34. Help needed for poor running sapphire 1.6 pinto
  35. Best place for leads, dizzy cap ect guys??
  36. what hp can handle a sigle clutch plate ?
  37. Mt75 Transferbox 4.1
  38. Sapph 4x4 front hub nuts
  39. Cosworth Restoration Help
  40. Aldusting camber
  41. Gas gold spring rates
  42. sapphire front wheel
  43. Msd coilpack on yb, same fireing order as ford one?
  44. spotted in suffolk
  45. sapphire adjustable tca
  46. Anybody got any info on H18 CJB moonstone saff
  47. ARB Shimming
  48. Next step advice please. Currently t35.55 and 55 injectors
  49. Sierra 2.0 DOHC brake upgrade
  50. Cosworth engine issue!
  51. replacing sump gasket advise
  52. Please help, Whats the story behind D40 NTA
  53. What's the story with this eBay RS500?
  54. Cosworth bumper brackets
  55. Car won't start plugs not wet but have spark?
  56. weld cosworth yb cyl. head or only skim to remove dent
  57. Engine cold idle problem
  58. New fuel pump loom which wires for the relay
  59. fluctuating fuel pressure!
  60. viscous fan
  61. 3 door standard exhaust housing
  62. Cosworth 2wd gearbox
  63. What was so special about the Sierra GT?
  64. Rs500 grill mesh
  65. '91 OHC 2.0 wiring/loom
  66. T-5 parts and motor mounts
  67. has anyone used or bought a head fromwww.cncheads.co.uk
  68. Bailey Turbo Dampner/Support
  69. Cosworth 4x4 gear cradle poly bushes
  70. anyone see this
  71. Sierra 2wd Rims
  72. genuine 3door front splitter
  73. tca ball joint help
  74. sequential gearbox for 3 dr
  75. Exhaust Hanger
  76. engine bearings/bushes
  77. Saff headlights
  78. comp brake pedal box
  79. radiator intercooler price/quality?
  80. Power limit of rs500 inlet manifold?
  81. 2wd pedal box repair
  82. Changing Pulleys from V to Multi V?
  83. REYLAND RS500 freshen up
  84. Rear calipers
  85. Diff fluid type
  86. YB turbo power upgrade
  87. Sierra 2WD with Ford 302 V8
  88. Engine Vibs
  89. brake resovouir hose
  90. Best place for a rolling road tune-Sheffield area
  91. 2wd head cooling
  92. SECS data stream monitor loom?
  93. Sapphire cosworth
  94. cosworth 3dr whail tale, spoiler bracket fixing how to???
  95. Cosworth 4x4 front AP 330 brake rotor sizing help 28 or 30
  96. Anyone good with electric windows?
  97. dump valve/ blow of valve questions sierra cosworth
  98. clutch for 2wd cossie
  99. 1.6 CVH engine swap to...?
  100. what dashboard bulbs?
  101. 'Lamp failure indicator' 87BG 10C909AA module schematic
  102. The ultimate Lurker has finally come out!
  103. Front hub washer
  104. favour needed....
  105. Brake options under RS7 Spokes
  106. Looking for car
  107. Ian heron's RS500 splitters ????
  108. idle control valve
  109. Newbie looking for info on YB's
  110. ignition feed problem? any ideas?
  111. 3dr side exit exhaust
  112. Yes, the Sapphire exists
  113. Sunny day, so out comes the Cosworth
  114. Cosworth 4x4 rear diff
  115. v6 Cosworth misfire at low revs??
  116. Cdf bumper brackets
  117. Tuners in hertfordshire?
  118. AP help
  119. Smoked side repeaters
  120. 3 door passenger floor section
  121. Indoor tailored car cover
  122. What power can I expect from my 2wd
  123. T-Belt Tensioner Torque
  124. L8 ECU / dwell regulation
  125. Rear Coil Spring
  126. Turbo shaft play
  127. Anti-roll bars
  128. 3DR - Lower Dash Removal
  129. biggest brakes for 16inch wheels
  130. biggest tire sapphire
  131. 3 door in door cover
  132. leather recaro spring.....
  133. cosworth ecu chip help please!
  134. cosworth t5 gearbox rear bush
  135. 3dr headlight refurbishment?
  136. Ideas for a 400+ build
  137. Saff cos side skirt fittings (need a favour please)...
  138. groupa a top mounts on ebay???
  139. Electric Power Steering Pump
  140. Rouse side skirts
  141. air charge temp sensor wiring help
  142. 3dr/Rs500 A post rubber/seals needed!!!!
  143. Rear Beam bushes
  144. Interior trimmers
  145. bladed arb
  146. Temporary steering wheel for 3dr?
  147. Removing loom plug from gearbox
  148. air con on a cosworth, retro fitting
  149. Check out my new car Saph BOA
  150. Ecu Master EMU
  151. Brembo brake upgrade?
  152. rear shocks
  153. Binding brakes
  154. Crank bearings
  155. mechanical/electronic wasted spark ignition system
  156. rear beam
  157. sapphire roof vents
  158. t5 gearbox
  159. rocker cover breather
  160. Fitting new cv boots to sapphire cosworth?
  161. Engine bay Stickers
  162. Bumper moulding!!! RS500
  163. Adjustable TCA's and Compression struts
  164. New Owner(Reyland)
  165. New gear stick for 2WD Sapphire
  166. sierra stalk wiring
  167. cosworth brake pedal gone solid. possible pressure switch?
  168. Turbo oil feed pipe rs500
  169. removing the clutch pedal on a 3dr cosworth?? help plz
  170. Rs500 bumper infill part no
  171. eletrical problems help please
  172. Autospecailist plenum throttle linkage
  173. abs light permanently on
  174. 3dr Body Shell Straightening & Alignment Jig
  175. forge actuator spring colour for garrett -31 spec
  176. Ford sierra cosworth cloth interior
  177. 3dr Cosworth Radiator fan wiring help
  178. 3DR Fuel Tank Help........PLEASE
  179. cams pulley
  180. Headlamp wipers
  181. T5 clutch for pivot pin?
  182. 2wd front alignment issues
  183. T38 turbo with a .48 exhaust housing?
  184. ARB bushes
  185. 2wd hydraulic clutch conversion help
  186. 2wd gearbox mount bolt question
  187. Having some paint
  188. over skimmed pistons
  189. 2wd Collins engine mounts
  190. 18in 6 spoke comps ET question..
  191. french sapphire
  192. buzzing sound from ABS master cylinder
  193. Sierra 2wd 1989 stereo placement
  194. What BHP saph 2wd cosworth
  195. ABS Pumps
  196. Alloy air box lid ??
  197. Cosworth anti roll bar bushes
  198. knock sensor wires
  199. One stop shop for sorting out the handling on my Sapphire
  200. Is it a good idea to have hub....
  201. Will Reylands 355x32mm 6 pots fit under...
  202. modules under dash
  203. New track control arms
  204. Starting fault
  205. Wheel Size
  206. Stainless steel sump bolts
  207. sapphire rear light gaskets
  208. How to decouple the fuel pipe on a saphire 4x4?
  209. Cosworth 4x4 lambda M18
  210. Master
  211. 3dr Misfire
  212. Dash temp gauge reading max all the time HELP!
  213. Fluctuating boost pressure
  214. Ahmed Bayjoo springs
  215. Sunroof visor - 3 door
  216. ECU
  217. Inlet manifold fitting
  218. Idle screw
  219. Found this
  220. Can i remove x member with engine still in?
  221. Fitting 044 Fuel pump
  222. 4x4 gearbox seals
  223. Radiator fan rewiring
  224. noisy fuel pump?
  225. Stainless Steel fuel pump cradles
  226. Saph 4x4 clutch help
  227. What brakes for standard sapph wheels
  228. MT75 gear stick loosening
  229. what's involved in putting a zetec into....
  230. New HT Lead Colour Choice
  231. moonstone blue sierra 3dr D95CRF
  232. 3 door cossie idle
  233. wiring loom demons
  234. Sapphire cosworth nsf leather door trim help! Will pay £££
  235. Sierra Cosworth '91 T16 4x4 - spark plug
  236. Few pics from today
  237. Advice needed please? 3dr sierra project.
  238. Black 3 door D827 YTL
  239. Painting ambers
  240. Air vent
  241. 3 door sierra cosworth suspension
  242. Sapphire 4x4 brake upgrade
  243. Open air filters and bonnet vents
  244. cracked 205 block
  245. T34 water pipes
  246. Amal Valve
  247. Lowest springs for 1.6 sapphire?
  248. Rear window switch removal?
  249. Compomotive TH'2 18in...
  250. strange starting problem
