T5 gearbox repair kit
Hello
Anybody any information where to buy a T5 repair kit ?
Found many in the USA for the World class box as (normally ) used in Europe for the sierra cosworth 2WD.
Serial numbers en year seem to match.
Grts
Patrick
Grts
Patrick
A good place for WC (T-5) repair kits, parts (Feks http://www.5speeds.com/cart/index.ph...&product_id=65) and advice ...
The kit from 5speeds is one of the best kits out there, includes reinforced syncro rings. However, the rear seal from 5speeds is incorrect so you will have to get this from Burton Power.
Its also much cheaper from 5speeds.
Remember to check the dogs on each gear for damage, as well on the syncro sliders. If the dogs are rounded off (they should be sharp and pointed like the roof of a house) then theres no point in changing rings as they will just wear accordingly.
Can you specify the "rear seal"
Whats the problem ?
155lee
24-10-2015 11:11 AM
