PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
  1. Standard yellow injector
  2. Removing front bumper on Sapphire??
  3. adjusting ap 6 paddle clutch
  4. Can you still buy clips for the centre vent
  5. Rear Beam Bended??
  6. cheapest place for???
  7. What would cause
  8. escos heat shield
  9. porsche trackday
  10. Bosch 403 Grey injectors
  11. Ecu pin outs
  12. Camber on 4x4 cosworth rear wheels....
  13. Refurbished T4 - what's it worth?
  14. Anyone running a GT35R turbo on a Cossie 4x4
  15. 2wd Front splitter
  16. Is this how people sell stolen Cossies?
  17. Do I need to re-face my flywheel to fit 6 paddle clutch?
  18. Brake pipes
  19. sierra temperature guage sending unit.
  20. Saff 4x4 cossie clutch cable
  21. How can I improve fuel economy
  22. next step?????????
  23. 2wd saff electric windows
  24. will a escort cosworth....
  25. HEAD GASKET
  26. What throttle body? Is there a big difference?
  27. OIL BREATHER/SEPERATOR FOR 4X4 SAPPHIRE COSSIE
  28. 8 injectors
  29. 4X4 electrical problem
  30. Ariel on wrong side, what do i do?? Going for paint! HELP
  31. BOSCH GREEN INJECTORS
  32. FORD MOTORSPORT BLUE PLUG LEADS
  33. BRIGHTER HEADLAMP BULBS
  34. RS500 INTERCOOLER,WHICH IS BEST
  35. SUMP GASKET engine in car
  36. Boost hose clamps
  37. removing rear halfshafts on 2wd??
  38. co reading at idle speed?
  39. Running rough in this weather.
  40. HOW DO I GET IN TOUCH WITH AHMED BAYOO ?
  41. [SEARCH] ECU cover black LHD
  42. SAPPHIRE FORD MUDFLAPS
  43. cossy calipers
  44. PLUG GAPPING FOR SAPPHIRE 4X4
  45. poly rear bushes
  46. won't start
  47. High emmissions
  48. Tickets for silverstone ford fair, how do i get them?
  49. Saff fuel guage lies
  50. How much boost T34 .63
  51. Just rebuilded my T3 4x4. Right chip needed
  52. sapphire 4x4 rear calipers...
  53. motor out/in
  54. t34 and exhaust manifold question
  55. 3 dr coilovers
  56. 200 block with a 205 motor questions
  57. Front wheel position in arches
  58. T38, L6, GREYS??
  59. Oil leaks from too high boost pressure?, Please help :)
  60. Sapphire head lining
  61. 4x4 or 2wd?
  62. Identifying cosworth 4x4 gearbox and diffs? Quick help pleas
  63. Cossie racing parts, what's it worth?
  64. wot oil to use on a fresh rebuilt engine(2wd)
  65. boost problem
  66. turbo?
  67. plenum spacer do they work ?
  68. cossie electrics
  69. BEST FOR COSWORTH MAPING NMS OR MSD ?
  70. rear trailing arm
  71. max boost on a t35
  72. MAP Sensor question...
  73. fuel lines
  74. engine rebuild think they taking the p@@@
  75. Cosworth cam covers
  76. spec-r oil catch tank
  77. Finis gurus, I need two centre caps for 4x4 alloys!
  78. Saph cossie 4x4 exhaust tail pipe
  79. msd mapped chip l6, greys new fit kit whats it all worth
  80. anti roll bar trouble
  81. Cossie clylinder head
  82. Best place for Cosworth engine parts.
  83. Will my ap 4 pots fit, if not up for sale!?
  84. 200 or 205 Block?
  85. Valve Springs
  86. intercooler
  87. Dump Valve Problem
  88. Vin Plates
  89. 2wd front calipers
  90. Rear brake pads. Halfords?
  91. Air injectors
  92. LEATHER STEERING WHEEL RETRIM
  93. 3 Door brake calliper??
  94. Do they do a Haynes Mannual for the 2WD Sierra Cosworth
  95. torque settings needed asap PLEASE ?
  96. My three door at le mans 2007
  97. COSSIE ROCKER COVER REFURBISHMENT
  98. Wider wheels at the rear on a 2wd Saph
  99. Coilovers: harsh for road use? Can you adjust them?
  100. Anyone know what this lead does
  101. Temp problem with 2wd Saph
  102. SPRINGS
  103. camber
  104. just changed my....
  105. 9" Diff or 10.5" Diff?
  106. Power upgrades for a std Saph
  107. 2wd Cosworth camber castor toe angles height etc.. UPRATED??
  108. Does SCC PERFORMANCE have an e-mail????
  109. T34 actuator bracket on 2wd
  110. Magnex or Mongoose?
  111. Cossie 4x4 WHICH PLUGS R BEST????
  112. about hybrid T3 4x4 into T34
  113. Help.....diamond cut rs to fit my saff???
  114. Difference between Saff 2wd and 4x4 Konis?
  115. Fitting new poly track control arm bushs.....
  116. samco/dumpvalve fitting ?
  117. Thinking of selling my 3 Door
  118. Big brake conversion
  119. Dizzyless cossie, rev counter problems
  120. iscv
  121. Tappety sound ????
  122. idle speed adjustment on a green top
  123. My 3 door ariel appears to be on the wrong side??? Help
  124. My 3 door ariel appears to be on the wrong side??? Help
  125. Cosworth cambelts
  126. best coil overs for a 3 door???
  127. wrc style cam trigger
  128. Got Stg 3 Greens etc, WANT to go Greys
  129. Oil consumption
  130. Group A coils
  131. what turbo?
  132. saff front bumper removal?
  133. 2wd saph what are flat out speeds on standard drivetrain ?
  134. My sierra won't start! please help...
  135. changing rear beam to 7.5"
  136. wanted pics of saffs with 17'' rs7's soft spokes fitted
  137. Escos Dash into Sapph?
  138. Valve stem clearance in bronze guide
  139. 2wd 4x4 power steering
  140. cosworth front crank seal
  141. going to MSD on monday
  142. engine vibration
  143. non starter
  144. Need Tim Finch contact info
  145. STAGE 3 3 DOOR
  146. Please help.
  147. 3 Door Whale Tail
  148. Additional Fuse Box
  149. 17" alloys
  150. Cossies...are they really so bad to own
  151. SAPPHIRE COSSIE 4X4 DOOR CARDS
  152. Long wheel studs (competition)
  153. Stainless Fuel Pump Cradle
  154. 3Dr Replica on ebay
  155. Original head gasket bhps
  156. Spark plugs
  157. MY NEW CAM COVER
  158. is this an rs 500 intercooler(pics)
  159. how long to spark plugs last in cossies ???????????????????
  160. 3 Door Cosworth ??
  161. cosworth 2wd brakes
  162. 2WD propshaft joints????
  163. Base setting PF09 TPS
  164. Is this a T3 turbo? Looks too small...
  165. Where can i get some TCA ball joint gaiters?
  166. Bore size
  167. 4x4 wobble
  168. Group A cambelt?
  169. rear shocks
  170. Water temp question (again)
  171. Inlet manifolds
  172. Diff problam...
  173. Some choice about exhaust manifold 4x4
  174. water cooling on t3 turbo
  175. 2WD FRONT CALIPER COLOUR??
  176. Breaking-in rebuilded YB turbo
  177. saffy oil presure
  178. plenum spacer
  179. TABETHA are you back
  180. Sapphire 4x4 colours
  181. restoration 2wd sapp
  182. my old cossie
  183. Cossie engines
  184. cosworth manifolds
  185. 4X4 Cosworth TCA
  186. 2wd front anti roll bar brackets?
  187. RS focus calipers on a 2wd
  188. My 3dr sierra cosworth, from Greece.
  189. stage 3
  190. My mighty oil pressure
  191. Saffire dashboard replacement - will the "facelift"
  192. pricing guide/value of my car request
  193. cosworth 2wd hot starting problem...
  194. Best springs Sapphire 2wd cossie
  195. xr4x4 2.0/cosworth parts
  196. rs500 identity
  197. aviod stone chips on your 3 door
  198. Lower wishbone length issues
  199. Need a wedding gift for my fiance!!
  200. Filter sizes
  201. rear beam
  202. brake conversion sierra 2WD
  203. Front suspension setting coilovers/TCAs/top mounts?
  204. Black RS500 on the A127/A12 last night heading east bound
  205. Fan Rewire
  206. please help aeroquip advice
  207. draining the fuel tank
  208. wheel sizing
  209. Still looking for a Sapphire Coworth wheel nut. Help pls
  210. COME BACK TABETHA
  211. Got bored at work.....
  212. F584PSN-WHITE SAPH COS 2WD-ANYONE SEEN IT LATELY?
  213. oil filter
  214. Rear bump stops/spring platforms
  215. xs power intercoolers and radiators any good ???????????????
  216. LAST POST
  217. rs500 - new motor problems - any thoughts anyone please
  218. Stone Chips
  219. help engine need rebuild
  220. help engine in need of rebuild
  221. PLEASE HELP, NEW RS ALLOYS WONT FIT!!!!
  222. azev wheels
  223. exhaust problems
  224. Can't get my left hand front driveshaft back in
  225. wot do u people think?????? too cheap????
  226. Is my starter motor about to fail?
  227. Steel ???
  228. Sapphire Value pics inside.
  229. cossie boost fluttering any ideas anyone ?
  230. pace cooler and rad
  231. setting a pf09 tps..
  232. Temp troubles
  233. ticking from my clutch
  234. sapphire pedalboxs
  235. intercooler hoses escort vs. 2wd saph
  236. What the difference?
  237. Stage 3
  238. Help needed urgently Sapp cosworth 2wd
  239. what clutch 4 a stage3 3dr
  240. boost pipes for XS RS500 spec intercooler
  241. no instrument warning lamps
  242. HOW U DETERMAIN WHAT COUSES WHAT SMOKING??
  243. 2wd handbrake cable removal?
  244. Fitting adjustable Coilovers like GAZ or AVO
  245. Compressor fluttering coming on to boost
  246. Has anyone ever bent their main shaft
  247. cossie cuttin out
  248. cossie cuttin out
  249. URGENT PLEASE HELP!!!!
  250. Group a K&N fitting
