PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
  1. new member, new cossie
  2. Heated Windscreen...
  3. roof rails
  4. Cosworth cam (which ones?)
  5. carbon fibre plenumn spacer
  6. cossie heaters
  7. Steering cuppling for the Sapphire cos 89'reg
  8. Fao Carbon people....
  9. Gearbox bearing replacement
  10. Sierra/Sapphire Cosworth Data for certification
  11. stripping t5 gearbox help ?
  12. 4x4 crossmember as a jacking point?
  13. Testing for a bad ABS sensor?
  14. Sump off - breather options?
  15. RP Lab users
  16. Stud length
  17. injecters
  18. cracked block - bin it or sleeve it?
  19. dose any1 have any sierra cosworths parts for sale
  20. took the cossy for a little blast tonight
  21. Floor Sound deadening
  22. cosworth exhaust who's??
  23. 3 door cosworth wheels on a sapphire cosworth.
  24. gear box change need help
  25. saph 2wd heat shield
  26. 4wd caliper help please
  27. 2wd cosworth diff rebuild??help..
  28. sapphire 2wd ecu needed ???
  29. Yellow ABS light stays on
  30. High CO and erratic lambda with MSD closed loop - Now fixed and info within
  31. Cambelt tensioner - OEM part quality?
  32. Mysterious switch in red-top 4x4 Cossie
  33. wheel bearing
  34. what oil
  35. missfiring problem
  36. my first cossie
  37. turbo not spinning..??
  38. duff diff..??
  39. brake resovoirs on saffs..?
  40. escos in harrogate N735 XXB
  41. Block
  42. Roll cage for 3doors Sierra?
  43. Cosworth Managment
  44. Weirdest thing you've found in your Cossie
  45. ECU CO2
  46. concourse 500
  47. Boost hose info????
  48. Fuses
  49. painting the cam cover
  50. what rack is this?
  51. Cosworth rear brakes
  52. Need standard chip for 2wd cozzy ??
  53. rich oil smell when givin large 2wd sapphire
  54. Effect of a dead ACT sensor?
  55. T5 gearbox strip.
  56. Rear arch liners
  57. 3dr engine wiring loom colours
  58. turbo pic request
  59. what pistons make YB non-interference?
  60. 4x4 burn engine oil
  61. turbo blown need to get home
  62. How much is a Tremec T56 Gearbox worth?
  63. Raven Leather Seat Repair
  64. rear panel
  65. 2wd cos problem no spark
  66. 4x4 hestiation on low revs
  67. Oil pressure 4x4
  68. abs light coming on
  69. 4x4 Saff clutch cable - easy job?
  70. with or without lower spoiler? your opinion plz
  71. our 3dr track car project!! :)
  72. ALS for Sapph 4x4 with P8
  73. 3dr spoiler brackets.
  74. how much 4escort cossie wheels???
  75. 3dr Gearbox Noise
  76. 4x4 caliper re build
  77. Saff cossie 4x4 oil filters
  78. engine trouble
  79. Rich smell from sapphire cosworth
  80. Solid rear mounts ticking noise
  81. Fuel Pipes
  82. 2WD Sapphire Squeaky belts
  83. 2WD Sapphire g/box and diff oil
  84. Saff - 3 Door Questions
  85. 4inch tail pipe
  86. Sapphire Cosworth 4x4 switch on LHS of locking panel
  87. Xsport Racing Ford Sapphire Cosworth Rear Spoiler
  88. Xsport Racing Ford Sierra RS500 Front Splitters
  89. wth are these?
  90. high iddle on sierra cosworth 4x4
  91. moonstone blue 3dr D848 xxN in harrogate
  92. Oil Pressure question....
  93. Cosworth recirc dump valve
  94. rear trailing arms
  95. Carbon Fiber Dash,Anyone ever get one?
  96. Map Sensor Bracket
  97. light sierra
  98. Temp Sensor
  99. Boost controller help
  100. cosworth fuel pump MOUNTS RUBBER INSULATORS?
  101. Would you pay 4500 for this?
  102. 4x4 diff ratio?
  103. Rear decal colour 3door
  104. cossie diff?
  105. Just fitted my new fuel pump wiring loom and...
  106. 3dr locking thingy...Lol...
  107. Diamond White paint - clearcoat on top?
  108. torque
  109. 3 door thud
  110. High rev misfire - 3dr Cossie
  111. sapphire 2wd door cards
  112. My Cossy drop away motor oil
  113. rouse for sale on ebay..
  114. how to lighten my sapph
  115. sapphire splitters
  116. High Pitch Squeel Fromm Inlet side (3dr Cos)
  117. 3dr turbo heat shield - how attached ?
  118. Fuel pressure and AFR
  119. can i still get new 2wd rear driveshafts from anybody?
  120. `cryo` kit for my i/c worth bothering with?
  121. Burton Power T-5 hydraulic clutch kit?
  122. Twincam Serria not starting/injecting?
  123. Group a wheel nuts again!
  124. ReMap or not?
  125. Front wings
  126. 225/45/17 to big for a saph??
  127. Calipers to replace cosowrth 4 pot calipers on kit car
  128. Half moon seals
  129. What Washer Size & Type ??
  130. Smoked rear lights for a 3 door
  131. Whats it worth?????????????
  132. Identifying AVO coil over spring rates
  133. prop donuts
  134. saph electric sunroof
  135. 2wd lowering springs
  136. Group a wheel nuts
  137. 2wd saff still vibrating
  138. What spark plugs?
  139. Uprated Gearbox
  140. sapphire 2wd interior
  141. brake fluid for my saph?
  142. 4x4 Steering rack seal kit fitting?
  143. noisy 3dr engine..help needed!!
  144. turbo coolers
  145. Best place to buy silicon hose
  146. RS500 build no 482 - gone to Malta
  147. Rs500 / 3dr Springs..... Advice
  148. rod bolts re-use ??
  149. tyre pressure for 225/50r15??
  150. vent gauges
  151. 4x4 turbo upgrade?
  152. 3 door
  153. Sierra cosworth servicing advice
  154. What to salvage from a 4x4 2.8i before it goes to da scrap??
  155. mouldings
  156. Removing the whole abs unit.
  157. tca pinch bolts
  158. Sapphire 4x4 radio antenna
  159. T34 hose advise
  160. Advice needed
  161. 4x4 overheating?
  162. No longer available my a--e
  163. T3 driveabilty
  164. exhauts
  165. boot springs??
  166. 4x4 front diff oil seal.......
  167. Self reclining recaros.......
  168. 2 bar map sensor needed ASAP
  169. tiger stripes
  170. Advise on chip/what ECU do i have??
  171. bolts and nuts for 3dr engine bay
  172. 3dr parcel shelf
  173. rear Quarter panels
  174. T35
  175. Moonstone 3 door on Anthracite Comp Mo's
  176. help with 4r4x4 2.9tt
  177. Can a faulty caliper feel like a warped disc?
  178. t9 box problem
  179. Mid life crisis
  180. Advise please
  181. Need a new Diff
  182. Help need parts
  183. tick over question
  184. early 3dr Oil ??
  185. Which is the fuel pump relay in this pic?
  186. biggest brakes under escos rims
  187. 205 engine build up advice
  188. 2wd clutch
  189. front tyre wearing inside
  190. He is on my tail
  191. Cosworth jacking points/floor pans
  192. Sapphire Rs500 front spliters
  193. how do you remove a 3 door engine loom??
  194. 2wd / 4wd engines - differences?
  195. rear calipers 2wd /4x4 ?
  196. cosworth bearings
  197. Sapphire cossie steering issues
  198. How many bhp for this boost is normal? UPDATE with graphics!
  199. Is it normal for pistons to sit proud of the block ?
  200. Breaking
  201. Clutch kit help needed
  202. Nice white 3 door on Piston Heads
  203. Sapphire boot seal, where from????
  204. help
  205. Gearbox and clutch
  206. What is this
  207. Sapph rear windscreen rubbers...
  208. Cheap 4x4 Cossie brake pads
  209. raffee
  210. Low idle when cold?
  211. low idle revs
  212. Air fuel ratio gauge
  213. Standard springs on a 2wd cosworth.
  214. Ford Fair Rolling Road..
  215. water temp sensor
  216. This guy needs to be shot...
  217. Blew a nice hole in my diff :D
  218. MOT time, panick!!
  219. turbo help
  220. Pics of Front End of Saphs
  221. Remote Oil Filter........
  222. Where is this bolt from
  223. Fuel rail mod.
  224. Rocker gaskets
  225. Oil pump cap
  226. piston caliper and master cylinder size
  227. 3dr High Idle
  228. 3 door fans
  229. Another engine bites it
  230. Urgent central locking / alarm help required
  231. wheel size for saph
  232. Smoke on overrun??
  233. Cheap dateless 500 plate available until Monday
  234. Fuel Pump Voltage?
  235. 2wd brakes, what are best ones
  236. Cossie 4x4 front driveshaft oil leakage
  237. Viper installation
  238. Turbo gone?
  239. Age of Cosworth engine??
  240. 18" wheels on a 3 door???
  241. Fuel pump relay + wiring
  242. Sierra 1.8 Turbo diesel fuel tank
  243. Saph rear shocks
  244. Fuel Pump
  245. Slim line fan,s
  246. Cutting out at 5000rpm?
  247. short shifter....
  248. Secs monitor
  249. Larger or replacement alloy rads???
  250. techy boost question
