4x4 diff ratio?
Old 06-09-2009 | 11:15 PM
wildheart's Avatar
wildheart
Default 4x4 diff ratio?
Can someome tell me the diff ratio's of the 4x4 cossie diffs?
Much appreciated
Old 07-09-2009 | 04:24 PM
I'm sure the 4x4 is 3.62:1, the 2wd being 3.64:1
Old 08-09-2009 | 03:30 PM
wildheart's Avatar
wildheart
Cheers Tabetha.
I've just got myself a 4x4 and been told by the last owner it has 3.6 diff's and to be honest i havent got a clue if they are standard ratio or not
Old 08-09-2009 | 04:23 PM
Yes std, you'd have to replace both if you wanted different ones, rears are no problem, front is somewhat different.
Old 08-09-2009 | 05:10 PM
m4tt274's Avatar
m4tt274
on mine i bought a recon front diff, but dident realise there a 3.62 and a 3.64. thers to differant ones
one for the 2,8/2.9 and one for 2.0
have same fitment but ones cossy ones xr4x4 v6 and ones xr4x4 2.0
and i got sold an xr4x4 one told it was cossy
so be careful with that
Old 02-12-2010 | 01:30 PM
seventhheaven's Avatar
seventhheaven
In Development
Hi,
A friendly man at the local ford dealer let me use his microfiche machine and I've managed to get all the part numbers, FINIS numbers, exploded diagrams etc for Sierra, Granada and Scorpios. I'm putting together everything I've found at http://www.super7thheaven.co.uk
Hope that helps - It's a work in progress
Old 02-12-2010 | 06:17 PM
tjRS500's Avatar
tjRS500
would it not effect a 4x4 if they are turning at 2 different ratios, e.g. v6 diff and 2.0 diff, likek put strain on the box??
Old 02-12-2010 | 06:39 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the cossie and V6 cars have a 3.62:1 ratio front and rear in 7 inch diff casings
the 2.0 dohc has a 3.92:1 ratio front and rear in 7 inch diff casings
the 2.0 rwd dohc cars have 3.92:1 ratios in 7.5 diff casings
the 2.8 front diff uses a different casing to the 2.0 and V6 and cossie diff casings, but they are still 6.5 inch diffs so you can't use the 2.8 front diff on any other sump
some people say they have made them fit, but it's easier to find the later diffs that "will" fit rather than ones that "probably won't" fit
the internals of the 2.0 dohc, 2.9 V6 and cossie 4wd mt75 boxes are all the same, the only differences are in the front casings
01-11-2015 07:53 PM
07-10-2015 01:56 PM
gcfcos
59
06-10-2015 06:04 PM
Iain Mac
30-09-2015 10:39 PM
DavidK
27-09-2015 03:55 PM
