2wd cos problem no spark
hi guys cud do wiv sum help on this 1. was out in the cossie the other nite and it jst died on me and jst wudnt fire up again.got it home and checkd it the nxt day it got no spark at all in any leads or plugs but ive got power to the grp A coil. it had a new rote arm and dissy cap last week and a new phase sensor an crank sensor an was runnin spot on. ive had a look round the engine to see if anyfinks a miss but i can't see out. the relays are clickin behind the dash wen the ignition is turnd on but wen try to start no spark.
any advice please lads thanks
More boost Igor!
Is the new CPS securely connected and correctly adjusted? It may not have been secured when it was installed. The gap between the sensor and the teeth on the crank pulley should be 0.6 - 1.0 mm.
Mine died (spectactularly) a while ago because the king lead decided it was time to end its relationship with the dizzy cap. So I'd suggest they're all secure too.
rite lads ive done the following checks
fuel pump primes wen ignit turnd on
the cps sensor is gapped to 1.0mm and all 4 lugs are intac
done a quick wiggle test of engine loom while trying to turn it over and still no spark.
bloody eletrics and sensors
i havnt yet checked to see if there is a spark from the king lead as none of the other leads wud spark. wots the chances of a grp a coil failing to work?
i wud like to swap the ecu to rule tht out but none of my m8s have a cossie cos they know the hassle i get wiv mine lol goin to ave a full day on it saturday to see if i can get it started.
wud the tps sensor stop the car frm starting at all?
Andy, i think i have a spare ECU you could borrow, i'm in Caerphilly South Wales, and could post it to you to try if you want. I will defo check in my toolbox for one.
Jason
Jason
you checked the fuse on the engine loom under the dash? mine got knocked by a mate in the middle of nowhere and took ages to find out.
but if you keep cranking over, when you find the fault, change the oil and filter, because the unburnt fuel might be thinnning down the oil and it will rattle your engine
HTH
HTH
jst finkin now if theres power to the coil but not not sparking,cud it be the king lead fukd? i have the blue magnecor leads and wud a 4x4 ignition amp wrk as i ave jst found 1?
ive had the ecu out and tht all looks fine but thanks for the offer nugnah
biggiejody.ive checkd the relays and fuse's every wer and they are ok
fink i'll jst ave to spend sum cash on a new loom,l8 ecu and sum goodies from motorsport develoments defo gonna go for wasted spark set up
old fords only
found wot the problem was it was the ignition amp. put the 4x4 1 on and a new rota arm and is fine now except 4 a lil mis fire butmite b dwn to lack of fuel in tank cos i ave change the plugs twice. thanks to all who responded to my problem
wheelwizardrefurbs
23-09-2015 09:14 PM
FlashRS
13
31-08-2015 06:02 PM
Zoggon
10-08-2015 10:39 AM
