low idle revs
Old 12-08-2009 | 08:15 PM
fezzajsy's Avatar
fezzajsy
Default low idle revs
cleaned the tps but nothing doing.revs low after i put a forge dumpvalve and rs500 cooler,any idea guys?
Old 12-08-2009 | 08:26 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
have you reset the base idle?
warm her up, unplugg the iscv, and adjust the base idle via the idle screw under the throttle body(brass screw) to around 900 rpm,
then reconnect the iscv and all should be well.
if your idle has dropped since fitting a new dv, you may find the old one had an air leak,inducing air into the plenum which would give you a higher idle speed. and for that reason it would be wise for a fuelling and boost check
Old 12-08-2009 | 08:42 PM
fezzajsy's Avatar
fezzajsy
cheeRS mate,very helpful
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
timsrs
13-11-2018 12:48 PM
01-11-2015 07:53 PM
fordrallycar
30-09-2015 08:57 PM
Tank Mike
26-09-2015 09:07 AM
