wheel bearing
wheel bearing
like to know if there is a difference between the left and the right rear bearing wheel
I umount the rear hubs of my car
and forget to remember with side each one is
so I like to check if I can recognize with side is each hub
thanks for your help
The bearings are defo the same, they will be different, they can easily be identified however.
The rear calipers go BEHIND the centre line of the wheel, if offering up the wrong one, it would put the caliper forward of the wheels centre line.
Adam Graham
06-09-2015 06:04 AM
