Stud length
Stud length
Hi all,
Does anyone know the standard stud length on a 3 door? And is it just a case of knocking them out or do you have to remove disc/caliper?
Cheers . T
Cheers . T
I don't know the std length, but sure ford would still stock these, easy to fit.
Getting the old one out is no problem, disc/caliper off, whack the stud, draw the new one in with thick washers under the wheel nut, so it doesn't mark the surface of the nut and pull in.
