tyre pressure for 225/50r15??
I always start at what the car maker says, then adjust from there, trying harder and softer in 2psi stages, can make a surprising amount of difference, just have a play with pressures.
Did you put these on std rims ?, do they rub anywhere ?
thanks tabetha,put new 15's on but still same size as standard rims,very slight rubbing of the plastic liner but only when on bumpy corners,thought it was the arches to start with so got my rolling pin and rolled them a tiny bit,but its the liner,on ggr spec srings so about standard ride height,thinking about putting bayjoo springs on rear to lower rear a touch,have re-adjusted pressures to 31 psi front and 32 psi rear and feels better so will try that just now,thanks again
07-10-2015 12:56 PM
