Cutting out at 5000rpm?
Hi,
Got a weird fault with the cossie,when it revs to 5/5500 rpm the engine stutters,the revs drop and then it backfires a couple of times and stalls?
Changed cps,act,ect-the only clue is that from cold the revs are below 1000 but when its warm the revs are 1100.
Any help appreciated,cheers.
My guess a problem with the dizzy.
If you have the change connect a led- or star-tester and read out the fault codes right after the problem occurs. If you see a code 13 then replace your dizzy.
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
cossirob
16-09-2015 07:39 PM
