Oil pressure 4x4
my oil pressure is 27psi on idle on hot engine, but when i go full trottle oil pressure goes to 36 - 44psi,sometimes only to 36psi, is this normal, i think that the oil levels shoud be higher
It's amazing even with fully synthetic how much noise there is with some oils compared with others.
I would never use anything less than a 50 weight, unless it's a new engine and you drive like an old granny at 30 everywhere.
The main reason for using a much thicker oil to start with is because they have such a hard time, especially with the very small capacity sumps it gets seriously thinned out, obviously starting thicker gives a bit more leaway.
Yes I agree different oils to have an effect on noise, Mobil 1 is renowned for being a noisy oil.
Guy
My oil pressure is 2bar (28psi) at cold idle and 3bar (42psi) at 2000 rpm (cold).
When warm oil pressure on idle is 1bar (14psi) and 3bar (42psi) at 2000 rpm. Do I have any possible issue with the pump, relief valve or something? The oil is 15W -50.
truffleshuffle
10-09-2015 09:35 PM
Adam Graham
06-09-2015 06:04 AM
