Advise please
Anyting forsale let me no
Advise please
As many of you no i finally got my car moted yesterday Great.
There is just a couple of issues like every cossy, at about quarter throttle there seams to be a little splutter and when you are on full beans some times it pops alittle like a miss but its not!.
Anyone with any ideas other wise its a little trip bk up to Mr scott at A1, he was the last person to touch it and it was spot on,
It just been parked up since last summer and yesterday was the first time on the road, the longer i drove it the better it got but it was still there, i did replace the plugs and gap them too .7?
any advise would be helpful as i want to boost about again soon
Get on That!
if setup correctly this should never happen, i've yet to come across a cossie of mine that been setup right that cough & splutters on WOT or when i come off the throttle
what dampness in the map sensor? how can you check the phase sensor
failing that get it setup ASAP by a proffesional
yep water or dampness in map sensor, remove the dizzt cap and check condition of phase sensor and the gap.
failing that get it setup ASAP by a proffesional[/QUOTE]
It was set up then i have just left it, apart from the hick up it is the same as when A1 set it up.
jus found the cause of a misfire on mine, similar to yours i.e. when under load.
It started on the way to FF, obvious id done something whilst cleaning the engine bay. When id had the cap off the sprung centre contact for the rotor arm had gone AWOL.
Only notice when i went over everything again t'other day.
DixieTheKid
11
06-06-2020 11:20 AM
massivewangers
30
01-10-2015 07:40 PM
Andypandy260
23-09-2015 10:28 PM
dange
Ford Mondeo Including ST
23-09-2015 12:11 PM
