Sapphire 4x4 radio antenna
oohmamama
Hi guys,
is there a box somewhere in my sapph 4x4 which converts the rear screen demister heater into a radio antenna? where would this be located? Does anyone know the part number or some sort of identification? I need to locate this if it exists and check it out my radio reception has gone horrible
Radio tuner and wiring already checked OK. Rear screen demister works fine.
Thanks for help
![fume](https://passionford.com/forum/images/smilies/fume.gif)
Thanks for help
More boost Igor!
As long as you've got a 12v feed to the red and white wire on the stereo loom, the rear window aerial amplifier should power up and work.
I thought my aerial amp was shagged - it just wasn't turned on because I hadn't connected it's power lead.
Your stereo should have an 'antenna output', which is usually used to power a relay that raises electrically operated aerials - connect this to the red and white wire. Job done.
