- 4wd intercooler????
- do esc cos heatsheilds fit a saph??
- cams ?
- saphire tyre info!
- clutch for 550 brake?
- Bonnet Underlay - Yes or No
- Changed my clutch - won't grip :S
- 7.5" diff into a 4x4
- close ratio ?
- Rear Beam Bushes
- BHP limit 4wd exhaust manifold
- stalite valves
- you need deep pockets.....:(
- t5, changing input shaft bearings
- are these the right plugs for my saff 4x4??
- Where is temperature transmitter
- 4x4 Saph front diff
- Saff splitter removal?
- speaker sizes..???
- Opinions on my non-working 2WD brake master cylinder
- Gt28 turbo
- Removing/refitting Saff front bumper?
- Mk1 Sierra Ghia 2.3 V6
- 205 block piston trouble
- Clutch needed
- 8j by 18 inch et30 ?
- Bonnet bra thingies??
- A few questions about parts I need..?
- Sweedish plenum.
- stage 3 boost ?
- Speedo not working
- Fuel line removal
- Wiring problems now!
- wide ratio/ close ratio gearing
- Removing TCA & balljoint
- closed loop
- central locking problem????
- my way of sorting the side skirts clip problem
- wot gearbox oil and diff oil for a 2wd cossie?
- 3 Door Ariel on n/s ??? Answers
- rs500 or swedish plenum?
- TÜV approval for springs?
- throotle cable lengh
- Coilover question?
- wot engine oil for a 2wd cossie?
- 2wd vs 4wd thermostat housings
- 2wd heat shield
- Racing Plugs
- 2wd head needed asap
- help mounting mongoose exhaust
- high revs
- overheating
- 3 door on escort cos wheels
- ngk bcr8es gap
- Couple of 3dr project questions
- Rewiring fuel pump
- 909 outter tca bushes
- AP Brakes - anti squeal clips?
- How hot do your Cossie's run?
- rim problem
- 3-dr Melted Fuse Box
- frothy power steering fluid
- opps...
- Mud flaps
- price for used rs500 inlet manifold?
- Need a piece of power steering pipe
- Standard sized direct replacement bells and rotors
- I need help
- 40k miler 2wd saph
- WRC headgaskets
- front diff oil seal
- Oil press/temp gauges
- Just been a muppet and dropped one of my pistons.
- sierra color code
- oil breather
- Gearbox Cradle
- cossie 4x4 tyres
- Camber out! 3 degrees one side, 0.5 the other!
- 2wd transmission mount
- discs and pads advise
- Drive shaft gaiter clip
- fuel filter
- sapph fusebox
- New Engine Looms
- Part Number Required
- Actuator problems
- dump valve....pipe goes?
- how many nuts and bolts should there be securing a turbo heat shield (saff 4x4) ??
- 2WD brakes to fit a 4x4 saph, how??
- clunking when turning
- Engine removal
- 4x4 Quickshift
- breather woes
- 2wd Arb Upgrade
- rad????
- tuning question
- mud flapz
- RST owner thinking off becoming cossy owner but!!!
- Sapphire front bumper removal
- moonstone blue 4x4 (H994HHN)
- HELP
- boost gauge
- Fitted 3 door cover
- indicator fuse
- diff/gearbox seals
- oil pressure
- oil breather advice
- under engine/susp cleaning
- straight swap?
- chassis leg on a sapphire?
- Escos turbo heatshield on a 4x4 Saph
- changing wheel colour
- damm car!!!!
- Rad fans arent working
- cossy wont rev
- hell of a neg camber on the rear
- Engine mounts, 4x4 cossie
- should i???????????
- clunking noise from rear
- Water temps
- help bloody cosworth won't start !!!
- Alcon cover clutch limits
- indicators not working :(
- 2wd Power steering pipe (rack to pump)
- HUBS - 3dr/2wd/4x4 what's the difference?
- Electric rear windows stopped working?
- strut brace?
- msd
- Sump plugs..??
- t5 clutch lever retaining clip solution
- Lowering springs 2WD <=> 4x4 the same?
- 15 X 8 wheels on a Sapph?
- Side skirt clips
- Would anyone be interested in carbon wings or bonnets
- gt30
- saff's with cut front bumper..?
- TPS for 2wd?
- compression ????
- Actuator hose size anyone?
- Can Anyone Help Please????
- cam cover info please
- What hose for a T34?
- Clutch sticky feel at top rev gear change
- 3dr Electric aerial
- head light choices
- Rear brake calipers handbrake cable issue
- 2WD clutch ratchets??
- Who are the best people to mapp my motor?
- what oil for my 3dr? ? ?
- 225/35/17
- Removal of the Rear trims on the quarter panel
- level 8 ecu, any chip with coil chip from msd
- 205 or 215 tyres
- Power steering issue
- What injectors
- After name of part. 3 Door.
- bad runner
- 2wd sapp cossie piston
- Turbo damper (head scratcher)
- sapph wont start
- Cos wheels (offset + stud diameter)
- Floor Pans
- 400ish bhp
- Saffy speedo...
- cone filters..
- head torque
- Saff lights not working.
- 3 door cossie HELP!
- Clearance b/w 3 door wheels standard
- not holding boost
- Throttle position sensor on saff cossie 4x4
- better brakes
- Cossie misfire
- Electrics
- 909 gearbox mount bother???
- strange problem
- What Carbon You Got
- Turbo damper
- spray job
- Tips on removing ECU?
- back firing at high revs
- Saff door rebuild
- Question about MAP sensors
- afr gauge
- help!battery warning light
- Pics of saff with morette's?
- Abs sensor
- 2WD fuel Pressure Regulators...
- Things to look out 4 when buyin saff?
- sapphire 4x4 fuel tank
- none starter...help
- 17" 3dr wheel clearance problems
- 2wd idle screw
- how can you tell if an rs500 is genuine
- Rims
- Cometic Rocker Cover Gasket
- Whats happened to the crystal blue resister
- Map sensor
- Rouse-sport-sierra-cosworth
- Cosworth parts in London
- Replacing the cassette holder in the dash
- 3door bumper on a saph
- gearbox
- cam caps
- cosworth grey smoke ?
- Re-wiring Fans
- Is it a cosworth?
- Saff bonnet bra
- dump valve plugging!
- Rouse Sport Leather - What is it worth
- Headlights not working need advice/help
- Cosworth rolling shell
- CO running at 11.5 - 12.0%!!!
- 3 door cosworth bronze windscreen
- cost for a stage 3 tune ?
- 2wd to 4x4
- location of sump plug,is it the one on the left or right??
- Which Diff Oil
- 4x4 intercooler help!
- sierra saph engine swop!!!!!!!
- 400bhp turbo???
- 2wd cossie
- Buying AVO coilovers - What springs rates for 4x4?
- Damn Bodgers
- 2wd hub
- ISKI double valve springs etc part numbers
- xr cos
- two things.....oil/swirl pot
- windows not working
- ABS Sensors need replacing on my 4x4 Saph
- from group A ARB for escort or sapphire
- Please Help, 1st time cosworth owner!
- Removing carbon build up..??
- oil cooling too much?
- how mutch intress are there for T3 brackets..
- wheels offset for cosworth?
- Lowering springs for a saff,whats ur reccomendations??
- Saffy mudflaps?
- jbfletch
- Trailing Arm Bushes
- sierra cossy +rs2000 parts on ebay
- Some boost questions
- sapphire rally parts
- problems with saph
- Should my car have lambda sensor?
- fit a racetech rev counter in saph clocks!! help...
- 18" Rondells on a Saff?
- 18 inch alloys
- Little pipe beneath the breather
- Please enlighten me; Sierra is, just in norway ?
