Standard sized direct replacement bells and rotors
At the moment I race on standard calipers, red stuff pads and standard size replacement drilled discs. I've been considering an upgrade but cannot go with bigger discs as the original 15" wheel needs to fit over the brakes.
NUTS RuS, what set-up would you recommend and do you think it would improve the braking?
2WD btw.
Charlie
2WD btw.
Charlie
I went from std cossie 2wd set up on my old sierra(2.1GL) to alloy bells with discs to suit, but still standard size and there was a VERY noticeable difference in resistance to brake fade, even with the same pads, I assumed the alloy was transfering the heat much better into the wheel etc than the all steel std ones.
Testing the future
i modded std 2wd 4 pots with a wider spacer to run with 330m discs and they were awesome. also had to mod the calipers to fit behind 17" wheels as the calipers are a bit big, but it was worth it.
2WD btw.
Charlie
2WD btw.
Charlie
What series are you competing in ? What do the regs allow for ?
Tony
Charlie
You could comission the ultra lightweight competition 6 pot to be retro fitted I guess.
With that caliper I'd guess we are looking at maybe a 285/290mm rotor/bell size.
How are the red stuff doing for you ? Winning any class points ?
Is the shell standard or lightweight and has the suspension had any upgrades
Tony
Tony
james kiely
28-08-2015 08:58 PM
Anutternutter
21-08-2015 06:07 PM
