2wd transmission mount
Old 02-06-2008, 12:22 AM
xr4man
xr4man's Avatar
Default 2wd transmission mount
it was pointed out to me today that my 3door cossie has a sapphire transmission mount. it appears that the sapphy mount may offset the trans to one side by a hair. i was wondering of anyone knew if this would be a problem? is the sapphy mount an upgrade for the original 3 door mount? and is it conceivable that the sapphire mount fixed a problem with teh 3 door mount and that i should just keep it or should i get an actual 3 door mount?
thanks
Old 02-06-2008, 06:32 AM
Don't do anything, afaik the 3 door was pressed steel, the sapphy one was alloy, that's all, the actual mount that bolts on these is the same.
Old 02-06-2008, 12:18 PM
xr4man
xr4man's Avatar
thanks. i'll sleep better at night now knowing i can keep the funky fresh alloy cross mount.
gcfcos
59
06-10-2015 05:04 PM
rsguy
44
29-09-2015 03:29 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
fordjames
Ford Focus Diesel
03-09-2015 10:20 PM
Quick Reply: 2wd transmission mount
