PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72]
  1. chassis no?
  2. 2wd rear brake wear
  3. L8 ECU
  4. CRANK
  5. Does anyone know the whereabouts of......
  6. Chip advice
  7. 4X4 BRAKES
  8. Advice buying a Cossie
  9. timing chains
  10. Recon Engine
  11. good or bad?
  12. Stage 1
  13. Milage?
  14. What engine oil do you guys use
  15. wot fuel
  16. what is the boost level on a standard 4x4 saff cossie??
  17. 4x4 SIERRA FRONT END
  18. headgasket anybody?
  19. Cams and Boost
  20. fitting konis to a 3 door cossie
  21. painting rocker cover
  22. fuel consumption stage 3 cossie
  23. Bottom ball joints.
  24. [b]Oil Cooler[/b]
  25. Inside tire wear on 1988 sapphire
  26. Help ! Oil breather.
  27. cosworth p100 pickup
  28. 2wd damper pics
  29. O-rings for 3 dr cossie alloy wheel centres
  30. Exhaust manifold gaskets
  31. exhaust studs snapped!!
  32. Basic and in-depth questions about the YB_ engine range...
  33. LHD T5 gearbox
  34. lookin too buy escort cossie
  35. Dodgy Steering. Suggestions?
  36. Intercooler
  37. RS 500 COSWORTH FOR SALE ON EBAY STARTING @ 10K
  38. whats the difference???
  39. cam cover bolt
  40. brooklyn ford tel no
  41. Saffy fuse blowing problem
  42. towing?
  43. Sapphire Cossie
  44. Newbie wanting some info
  45. Sapphire Cosworth - Whats it worth?
  46. Decent Garage required near Hereford.
  47. 3dr cossie brking pad warning light
  48. fao rob carden
  49. Saffs
  50. headlamps for a 3 door cossie
  51. COZZI (CDZ71) reg plate on retention
