- Chamber/toe change when lowered?????
- cosworth fuel problem
- anyone know where my old 3dr is???
- how do I dismantle side mirrors
- 2wd Powersteering Rack rebuild help!!!!!!!!!!!!
- cossie looms?
- What power should I expect?
- Cossie cough (Rain water)?
- can u run grays on standard fuel pump?
- cosworth running probs
- fitting cos saph skirts to a xr4x4
- Head Differences
- no brakes
- bosch 044
- Cosworth sump drain plug size ?
- 3dr rubbing strips lengths?
- where to get a new sapph petrol tank from
- Lowering a Sapph...
- Saff 4x4 fuel flow and return quick qeustion
- I'm new and in Australia ! Help please !
- trimming a samco hose?
- 3 Door Washer Jets
- How to increase your oil pressure with a pinto oil pump
- K670EBF saphire 4x4 anyone on here
- Why is my saph running worse when turning down boost?
- gt 30 and external wastegate
- Cosworth tuning T34, Greys
- Compbrake Tie-Rod Ends
- What Oil For My Sapphire 4x4??
- T34 rebuild required Where ??
- New 3 door dash top on Ebay
- what size vacuum hose
- 2wd sierra cosworth finishing of
- clutch for 4x4 500lb ft torque
- Sill trims and whats this? More about ECU now...
- Sequential RWD gearbox
- Help with saph K929MMW
- should a T5 box bolt up to a 4wd shell???
- Sapphire models......
- What oil would you use in this engine ?
- Anyone breaking cvh
- 2WD hydro clutch pic request
- Rear Arms
- Powerflow exhausts ????
- 2wd fuel pipe to fuel rail ??????
- brake compensator valve
- Original Ford Cosworth datasheets free pdf
- Is this correct fuel pressure ?
- Uneven 3Door ride height
- L6 ecu melted pins ???
- Dummies step by step guide to ABS...
- Only 1112 Miles in 6 and a half years!
- 3dr missfire
- Propshaft center bearing mount question
- I think I have the wrong seal, or have I
- Price Guidance?
- bore size
- Cosworth specialists in dorset
- 4x4 Intercooler.
- best headgasket?
- Front and rear diff. rebuild with pics.
- Phase sensor / Dissy
- My homemade custom breather system with pics.
- Sierra Cosworth Help please
- Who has MSD (CDF Racing) pulleys fitted
- whats my car worth in bits/ IS IT WORTH 10.5K COMPLETE
- Brake Pedal Kicks Back!
- brake line thread
- who is running GT30
- Where does this cable go?
- Any saf's wit 13" wheels & big spacers here??
- saph steering rack
- T5 Input shaft
- Ford Stereo Wiring Connections
- Steering coupling replacement?
- My latest Saff photo's G22 TMJ
- 2.0 engine work?
- strut tops...
- 4x4 to 2wd
- Gaz Gold Rear shocks loose 4x4
- Cosworth rear ABS toothed cog ??
- 2WD stutters at a certain temperature - HELP!!
- electric window failure
- rear lowering springs?
- sump guard 2wd sapphire?
- poly bushing??
- bought this on sat!!!
- Pillar guage mount
- Do sapphire's have a starter motor relay ??
- Sapphire Doors
- sapphire side skirt pop rivets??
- gauge side mounting base
- ford p100 engine
- cts gearboxs
- sunroof
- Sierra 1.6 cvh
- 3dr cosworth rally tarmac spring lbs??
- headlamps
- Sapphire (2WD) problems!!!!!
- Wheeler Dealers Cosworth?
- my new car
- 3 bar MAP at std chip?
- Rear Arches Sapphire
- Tremec T 45
- abs light on saff cured! thank f**k!
- Saff cossie 4x4 play in turbo shaft
- uprated 2wd gearbox/gearkit?
- Further to my thread on "Stronger Cambelt"
- Boost loss ... why?
- Sierra cosworth turbo
- sapphire side skirt clips
- 3 door dashboard
- evo 5 brembos
- saph cos g100 ond info
- turbosystems chips any good...
- bulbs for sapphire
- 3dr 4x4
- no boost
- What Oil
- its fixed at long last
- Paddle clutch - STD cover
- anyone know this big spec cossie/anyone on here ??
- Saff cossie 4x4 steering rack.
- Oil pressure switch 2 wire ???
- 4x4 engine mounts
- Looking to buy
- Airco on 92 sierra cosworth with rs500 cooler and how to change over ?
- cars!!!!!!!!!!!!
- Braided brake pipe fitting SORTED
- Genuine ford oil filters
- Cosworth guides install
- Throttle Position Sensor
- engine annoyances
- braking disaster
- Missfire just got stranger.
- opening up scorpion for stage 2 MSD ?
- how much power
- norris motor sport
- max power for a 4x4 throttle body
- Rev counter not working
- hart inlet or swedish type
- Stronger cam belt?
- Knock sensor
- Big intercooler---is it that much better
- Output shaft nut MT75
- lamp failure box
- BRAKE SERVO,MASTER CYLINDER question
- Cosworth Rally Car Registrations ( Irish )
- Parts price
- Std Head Bolts
- 3 door conversion
- how low can you go at the front?
- 2wd Saff wheels
- any one know this 3 door
- Sapphire cosworth prices
- How low does your exhaust hang?
- Rs500 cosworth prices weakening
- diff
- Biggest cooling capacity Sierra radiator ?
- oil pressure when engine shut down 1,5 to 2 bar ?
- saph cos door protectors
- Fuel pumps
- tach stopped working
- Unknown button in dashboard
- mudflaps for a 3dr??
- erratic rev counter
- ABS sensor on sapphire cosworth
- Has anyone a 4x4 head up for grabs
- Sierra exhaust
- 2wd/4wd cossie gearboxes
- saph rear beam the same as 3dr???
- Headgasket thickness
- Fuel hoses?
- ABS Transplant
- another diff question
- Anyone ever put a mk1 Sierra front end on a Saph?
- Mudflaps
- Crank sensor bracket
- 3dr and sapphire mirrors the same?
- rear beam difference 2wd/4wd??
- still wont start. GRRRRRR
- inner arb bushes - prob silly questionl...
- anyone after an RS500 kit in fiberglass?
- Cosworth head porting
- RPM dancing above 3500
- Got a new turbo, now a little help please!
- New Exhaust - pictures added
- Fuel pump cradle rubbers
- Spec Check
- suspension
- new coil, which one??
- fuel pump question
- fuel hose
- Air filter fitting help.
- Cheaper way round this bolts???
- Somebody please help end of teather now
- help
- l6 to l8 conversion what do i change
- Cossie Interior Question.
- new ap clutch set still slipoing
- 3 Door Moonstone Cosworth
- T5 rebuilt manual
- My nice new seats
- Heater matrix hoses
- Magnetic Drain plug 2wd
- turbosmart rpm signal problem cosworth
- injector refurbishing???
- Wiring Loom Q's
- cosworth running gear
- 3dr rims?
- Sierra SECS monitor owners
- T5 gearbox oil!!!!!!!!!!!!!!!
- Cosworth WRC pistons
- type of track control arms
- 18" wheels on Saph Cossie 2WD - optimal ET ?
- Please help with cossie missfire/hesitating/oil burning
- my cos what power...
- Cosworth std cam timing
- just out of interest...
- Removing standard air filter to fit cone filter
- Brake problem
- 17inch wheel sizes?
- oil pressure t piece
- 2WD gearboxes
- Spec me 450 bhp then...........
- ecu
- idle rev problem on saph 4x4
- YB engine rebuild diary w/Pics
- Fans playing up????
- CAMS
- Larger 3 Door Arches
- Help! Where to buy?
- Rear disc conversion
- Warning light on dash of 3dr
- wire for oil pressure switch
- 2wd headertank replacement advice
- Photo Request
- Sierra Cosworth 3dr sideskirts
- Fuel pump connectors
- Bypass valve after fitting 500 style cooler
- Saff cossie 4x4 engine mounts.
- 3dr owners quick help needed
- uneven idle
- Removing fuel tank
- dash insert
- Will not run over 5500 rpm?
- 500 splitter
- aeroquip fuel
- pic request of the section to cut out to convert to 4x4
- What do you think of these alloys
