2wd fuel pipe to fuel rail ??????
Does anyone know the part number for the two O rings I have asked the local ford parts dept but as usual they can't find them on there system,
also are they a special type of O ring as mine are white in colour if not then would normal ones be Ok to use with Fuel ?
NO absolutely not, do not use normal "o" rings few are petrol resistant, they will no doubt be balls I can't remember the material name! or similar o rings, just take one off and measure it then go to local seal supplier, if you get stuck pm me with dims as I can get these, cheaply.
Cheers tabetha I might take you up on that if I get no joy locally, I have tried a couple of places with no joy but was told by one chap that they are called Viton O rings does that ring a bell.
FlashRS
13
31-08-2015 06:02 PM
