- 3dr ecu???
- steering coloum
- WRC Headgasket 3 or 4 layers?
- body panels sierra
- How difficult to change engine mounts
- throtlle RS500
- Gear box oil
- What to look for when buyin a 3dr sierra cos
- mondeo rims on a sapphire..
- Turbo oil return - for breather too maybe?
- LOST ALL POWER
- what atb/ lsd
- short block question
- overbore limit
- Quick fuel filter question
- plenum for sierra cosworth 2 rm for moore 400bhp
- Looking on the Autotrader and Pistonheads...
- Headwork needed/advised for stage 3?
- Recirc D/V help (pic)
- Buying a 3 dr sierra cosworth (wats it worth)
- P100 conversion Q's
- Any EASY way of removing the front struts on a Saph?
- Cometic head gaskets!!
- pics of a hydrolic clutch conv for 4x4 please?
- 4 paddle clutch
- Junc 28 E plate Saphire cosworth
- indicators problem
- Pic of rouse front splitter please??
- plug gaps on coil pack con
- Rouse front splitter
- diff and gear box oil 2wd
- Cosworth throttle diameters? pics inside
- SPARK PLUGS
- NO BRAKES and then BRAKES?
- What oil should I use in a 50k engine?
- Sapphire 4x4 weight?
- 3door interiors and bay's
- Noisey cossie tappets
- Emissions too high
- After 15 reliable months its started!!!
- 3dr wanted for wedding
- FITTING 17" RIMS TO A SAFF
- help!!!!!
- group a coil / motorsport leads ?
- saph cossie breather pics
- 3dr inner wing question
- Saff 4x4 and 2wd brakes
- Little end pricing???????
- Is this high even for standard Saph, back end??
- White Sapph 2wd Cos, Valuation pics
- K Plate Saffs
- Fitted the K&N, some pics with liner out!
- cam pulleys...
- Tyre choice
- Saff rear hub nut size
- Removing the air box from Saph
- Got the Saph back and got nabbed by speed camera!! Arrgh!
- lowering a saph
- Can you buy a Haynes Manual for a 4x4 Saph?
- What thread sizes
- best offset with 17s
- Experience from R&D 6-speed
- 3 BAR MAP SENSOR
- RS 500 INTERCOOLER
- Sierra hub
- Whats it worth???
- Bad news on the Saph, do I shunt it on or keep it??
- DO I MOT IT OR BREAK IT UNDECIDED
- 2wd cossie diff overhaul
- Will 235/40/17 tyres fit on my Sapphire
- where does the oil go?
- Sapphire rear chassis rails
- Anyone got any nice big pics of a K&N on their Saph?
- Leather interieur?
- OIL PRESSURE
- Sapph juts gone wrong guys help!
- saff rear tyres
- Do you think this is the problem????
- Is The Speedo Cable A common One!
- sapphire white
- running out of fuel
- What does this do?
- is a 4x4 cosworth diff offset?
- Found the original ad for my Saph!
- lil help please :)
- Heaters
- Strange noice..
- Anyone got
- Is my Sapphire a rare colour?
- Idle speed on 1200rpm
- RS 500 Intercooler
- What do you think?
- price estimation
- Do Girls Drive 3 Doors?
- BRAIDED HOSES
- moonstone 4x4
- Help Fellow Saph Owners - Fans Again
- price and preference of sapphire rs cosworth
- please help a newbie
- Cossie / XR fuel pump / tank
- Removing side skirts to inspect for rot on sills
- 2wd and 4wd inlet cams!!
- koni sport rear shocks!!
- New production side skirt clips
- Help pleaseeeeeeeeeeeeeeeeeee
- Breather question (urgent help needed plz)
- New Turbo on a 4X4
- Who makes blue coloured springs?
- dump valves for 4 x 4 cossie
- Look what i just picked up guys!
- 2 less saphs: post pics of your scraped Saphs
- fuel pump
- 4wd calipier swap?
- 1 for the suspension guru`s (pick-up points)
- Skimmed head
- Whats a mint sapph shell worth
- antilag
- side skirt question
- EXHAUST MANIFOLD STUDS AND NUTS
- 4x4 intercooler questions....
- K and N, worth it?
- any one got pics of a cossie 2wd standerd intercooler?
- Oil being blown onto Boost house.
- what would a bottom end rebuild/freshen up cost on a 4x4 eng
- Autronics help?????
- cam cover breather pic`s needed
- Oil leak on new engine..
- AP 4 paddle clutch or Alcon 6 paddle clutch?
- Rad Fan relay?
- Power V's torque
- I can't believe this crap Saph is still for sale..
- Wheel question......
- sapphire cosworth spoilers- solid or hollow?
- what brake options is there?
- saph cos 2wd engine mounts - availability ?
- cossie revs sticking
- Saph Cos 2WD Rear coilovers? *Now with pics*
- Ford Badge
- cam cover
- Can you buy the Rouse Bodykit
- door mouldings
- plug reccomenations?
- Cosworth phase sensor - anyone changed one?
- Radiant red cosworths
- Anyone tried Mike R's wheel shims for a Saph?
- Alternator
- CTS quaife/T-5 gearbox ???
- 3 pipe breather system parts
- boost problems
- Saph Rs Cosworth - Little Car inside help
- Probs Fitting 4x4 Heat Sheild
- dump valve and chatter
- Advantage/Disadvantage removal of dump valve
- saph and 3 door seats- same fixings?
- Change oil pump with engine still in car?
- Wheel wobble still there! Could it be CV's or wheel bearings
- Compomotive MO's
- Cosworth problem. Misfiring on boost
- Greenlight Insurance - Stage 1 conversions Free of Charge
- Where can I buy some decent spigot rings for my wheels from?
- OSBOURNE BIG TOOTH GEARBOX?
- front inner cv joint, quick question
- 4k missfire
- RS500 cooler fitting
- Saph oil pressure t - piece
- Is there any issues by fitting escos wheels to a 3 door?
- diameter exhaust/ torque
- help please!!!
- Clutch Advise
- Fuel pressure
- carpet
- sapth problem
- Finally found out what my wheel wobble is!
- bosch 044 or what ?
- H29 GAC
- 4X4 wont rev
- ignition live
- Oil feed 2 the turbo
- Tickover help
- bodyshop repairs
- Boost spike - what causes it? How can I cure it?
- Polished metal question
- Saff 4X4 Gearbox
- Some pictures of my Sapphire :)
- mineral oils
- Alloy wheel lock
- HOW MANY SMOKESTONE BLUE COSSIES WERE MADE/ARE LEFT??
- saphy exhaust manifold 2wd or 4wd
- no spark
- PAS Pipe removal
- How to get Chattering on a 4wd cossie????
- Paintwork dilemma
- Fit and tension tootheed belt
- What wheels look good on a black 3 door?????
- t34 what else
- HELP.........LOOKING TO BUY A COSSIE
- 18" on a 3dr cos
- Steering judder on 4x4 Sapphire, please help!
- BMW 320D any help not starting
- BODY PANELS
- brand new 3 door shell ideal for re-shell/ project
- battery wires help
- underside sealing on a 2wd saph?
- wight cosworths
- are 2wd and 4x4 props different lenghts?
- cosworth car cover
- Gauges
- Wheel balancing problem!
- where to put the map sensor...
- rear diff ratio
- Head Gasket
- Sunroof removal for Motorsport??
- Drooping Mirrors
- dark blue inj
- What chip may I take for stage 2?
- Insurance - any good deals out there?
- Tyre Pressure's?
- front driveshaft solutions
- Newbie saying hello
- header tanks
- Was wondering how many 3 doors are left on the road
- New to the forum
- RS 500 prices
- How much is this diff worth
- pectel boards
- How to repair cracked cosworth bumpers
- Which turbo?
- Sunroof well rust?
- J300 COS where is it now ?
- 4x4 rear anti roll bar onto 3dr?
- RS500 Cylinder Head
- Problem with Lights or is it???
- Does the Sierra Cosworth have a swirl pot as standard
- GT2871R cossie , what chip/setup ?
- Sierra 1600 to 2000
- leaking boot and fixing side skirts
- RS 500 parts
- escort coss wheel swap wanted
- Worth Replacing 4x4 Oil Pump When Doing a Rebuild?
- Cosworth shell
- I take my hat off to you MR LEWIS
- Sierra Cosworth advice
- gt28rs on a cossie engine?
- coolant
- 2. Fuel line OR bigger fuel pump ?
- My saff
- stores rs500
- 7" and 7.5 " is there an easy well to tell the dif
- RS500 Altenator bracket
- alarm problem - Help needed Urgently!!!
