Cosworth phase sensor - anyone changed one?
It's been suggested that my misfire problem might be due to the phase sensor in my distributor.
Has anyone changed one before?
If so what is involved and how hard is it to do?
Thanks
Thanks
Ive done mine mate, and im shit at doing mechanics . dis cap off , you will see the sensor ,make sure the wires are ok (mine were nakered) then theres 2 screws either side of it ,undo them disconect the wires ! When fitting the new one you have to gap the sensor ,i cant remember what it is tho
Had a missfire,the two wires were broken mate, you just have to take the dis cap off,then pull the rotta arm off , and you will see it
www.burtonpower.co.uk there Ł25
I've got a misfire at roughly 4k coming on boost so hopefully this fixes it I've just bought one off of ebay.
I'll take my distributor cap off tonight and have a look at it
Thanks
Thanks
Originally Posted by paulpalmer
Blimey that's a small gap How do you do it please? Is it just a case of tightening it down once gapped? I have no idea
As above and then rotate around to the next cam and check that too.......
But ensure you have the engine in the right position in the first place relative the the crank.
Then you can take it out, fit the new and gap as above.......
That sounds easy. Is there a timing mark on the crank pulley that you can use to get the engine in the right position?
Thanks
Thanks
Anutternutter
21-08-2015 06:07 PM
muz
16-08-2015 12:57 PM
Zoggon
10-08-2015 10:39 AM
